Member Since 01 May 2014
Offline Last Active Feb 25 2015 07:28 PM
In Topic: A Common Problem They Say...
04 May 2014 - 08:43 PM
Windows are a pain in the glass" as they say in holland :lol:
Very good, they are indeed, but I assume I can adjust it to sort it... :rolleyes:
04 May 2014 - 08:17 PM
Hiya Me again.. :)
I have had a knocking from back end, well I thought it was something to do with the rear bumper as it was extremely loose, so have put new clips and bolts in and it is now tight.
But still getting knocking, so I was wondering if it could be the petrol tank, which may be loose and bumping body, the reason I ask is cause, when I filled up earlier today, I put the petrol pump in to fill and the whole tank filler neck came out of rubber seal and went down a bit, I managed to pull it back and it hasn't done it since as I check it now and again.
Could it be the exhaust bumping the body, although the rubbers seem to be fairly rigid still, it seems the bumping is coming from the rear middle of boot to nearside rear wing... :wacko:
I hope it not rear shocks, cause my ST24 had that problem..
Any suggestions...
01 May 2014 - 06:29 PM
Oh yes,
The other thing is, the Exhaust Heat Shielding just in front of the rear wheels has come away from body and is banging on the floor pan, (assuming it is not the actual exhaust, due to exhaust mounts/rubbers are not to slack) do you think it would matter if I took it off completely.
Cheers again,
In Topic: Hiya, Newbie On Here...
01 May 2014 - 06:06 PM
Thanks very much... :)
Do we have any owners of Cougars, I hope it not just me  B)
