Support the club!
yaflaminmongrels
Member Since 13 Mar 2008
Offline Last Active Mar 13 2008 11:59 AM
Ford Focus clutch problem?
13 March 2008 - 11:41 AM
Hello. I currently own a 2004 Ford Focus 1.6 Edge, which I have owned since April 2006. I purchased the car when it still had Ford Warranty, and the mileage was very low (11,700). A few weeks after, changing gears became difficult, stiff etc, and the clutch made a ‘whining’ noise each time it went up to the biting point, usually this would happen in 1st or second gear when the car was cold. It usually went away after. I spoke to Ford on the phone; a lady said that clutch, gearbox etc wouldn’t be covered under warranty because the parts were ‘subject to driver abuse’. I got them to do work under the warranty (long story!) and the Foreman said that the clutch had ‘worn out’ and the gearbox ‘selector shafts were bent’. Few months after, the water pump went, which I paid my regular mechanic to do (outside of warranty).
However, recently, the clutch problem has flared up again. When I start the car, put it in first, clutch up to the point to pull off, then the whining noise. First time each morning it is likely to make that noise 90% of the time. It sometimes makes the same noise when I drive during the day. I have been told that this could possibly be a common fault, but I am getting a bit worried now, the biting point also feels slightly high, although two people who have driven it to test it say its OK. Anyone help?
