ConradBuff
Member Since 08 May 2014
Offline Last Active Jun 06 2014 08:19 PM
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
22 May 2014 - 01:39 PM
I remember back in my VW days on one of the forums was a list of guys who had the VAG version of this, their location, the capabilities of the hardware/software they had and their 'contribution' fee for helping members out with diagnostic checks, activation of certain conveniences etc. Would it be possible to do the same for this on this forum? Im not lazy, or a numpty and will probably attempt this at some point but time is my enemy. However, Id be quite happy to give someone £10 say to turn on automatic front heated windscreen, would save me a load of grief next winter!
Anyway, just and idea. Means those that cant still get the benefits and those that can get reimbursed for their efforts.
Let me know your thoughts, happy to help putting a list/table together.
Cheers,
Rob
In Topic: Mk2.5 Xenon Headlight Conversion
11 May 2014 - 10:46 AM
Thats all I needed to know, thanks Andy!
Rob
10 May 2014 - 09:11 AM
I bought a pair of genuine ST Xenon headlights off of eBay. I managed to get all the lighting on the lights working, but i cannot get the levelers to work.
I understand that there is a wiring modification that can be done to get the levelers (manual or auto?) working.
6E27D75D-F299-444D-8153-89056E77D22E_zps
AD566796-F3DA-4656-8D9C-8BDE7E5D562F_zps
Any help would be massively appreciated!
Thanks,
Andy :)
Hi Andy,
I have a set of Xenons on the way to me but I have the 7 pin plug as well. You said you got all the lights working, was it as simple as just plugging them in and hey presto or did you have to mess with any of the wiring? Looking at the wiring diagrams it looks like there might be an additional earth needed from pin 8?
Any help would be much appreciated.
Cheers,
Rob
Gdd
In Topic: Rear Brake Conversion Focus Titanium Mk2.5 1.6
09 May 2014 - 04:20 PM
Most rear disc brake parts of the Focus MK2 and MK2.5 are identical. Only the parking brake cables may be different between some modelyears. Usually this can be solved with minor modifications.
note that there are different brake disc sizes between the different engine types. Your car should have 278 mm brake discs at the front. Cars with 278 mm front brake discs should have drum brakes or 265 mm discs at the rear. If you want to buy a complete rear axle you have to find one with 265 mm discs.
Thanks! PM Sent.
Rob
09 May 2014 - 10:17 AM
Hi guys,
New to the forum. Have just picked up a 2010 1.6 TDCi but it has drum brakes at the rear so interedted in upgrading with this conversion. Im going to try and source the main components second hand, do you know if there is a difference between the Mk2 & Mk2.5 parts? I have seen a few complete rear axles for sale that look perfect but are from circa 2006 so unsure whether they will be the parts I need?
Any help would be appreciated.
Thanks,
Rob
