Member Since 12 Apr 2009
Offline Last Active Jun 09 2013 02:57 PM
In Topic: Little Confussed Over Spark Plugs I Got Today.
23 June 2012 - 08:01 PM
As long as the plugs are the same dimensions and the gaps are correct you should be ok.
If the plugs are longer than the original ones then definitely do not fit them as they will likely hit the piston heads.
Hi thanks for the reply i will compare them with the ones i am taking out and see how it goes from there. Cheers
