mike-evans
Member Since 19 Apr 2009
Offline Last Active Aug 10 2010 05:28 AM
#60693 Bent valves=smoke?
Posted by mike-evans on 18 January 2010 - 09:53 PM
the smoke and tapping is because the timings out i doubt its damaged the valves ide have had the timing put right then see if alls ok
we took it to a garage and he said it was 2 teeth out and so adjusted it in, then it was stil smoking? When timing belt was being done the guy rang and said hg was on its way out/gone, so had it skimed and new gasket fitted. So we think he took shim buckets out and fitted back in wrong order= tapping, need adjusting? Why would it smoke though, smoke from burning oil? But how/why?
