Member Since 22 Mar 2008
Offline Last Active May 14 2011 10:05 AM
In Topic: diesel running lumpy over 3000rpm
23 December 2009 - 06:09 PM
Could be fuel pump on its way out or injectors. 3krpm in a diesel is very hard driving. I normally aim to change up by 2000-2500 rpm, dont forget the TDDi "redlines" at just over 4000rpm
had a freind check my car with a fault reader comes up with P0149 -fuel timing error car running very bad will not rev and a lot of blue white smoke unburnt fuel i was told i got a new timing belt fitted about a month ago is this any thing to do with it not loosing water or oil hope some one can help thanks mike
In Topic: strange noise
19 November 2009 - 11:59 PM
Probably the tensioners faulty. If the noise has only developed since it was changed, chances are thats where the fault lies.
thanks for the reply but they tried a new tensioner and noise still there some one said that it might be an air pipe to the turbo that they may have damaged they are going to have a look
In Topic: best glass cleaner
09 September 2009 - 09:50 PM
thanks for all the advice wil give some a try let you know how i get on thanks mike
In Topic: headlight condensation
03 September 2009 - 05:44 PM
thanks for all the help will giv it a try
In Topic: fan running all the time
03 September 2009 - 05:42 PM
Have you checked the coolant level, because my Focus' fan kept coming on with no irregular temperature gauge, but the I checked the coolant level and it was low. I've just had the Thermostat Housing replaced, as this is where the leak was.
Just an idea?
hi yes coolant level fine seems to be ok
