luk
Member Since 09 May 2009
Offline Last Active May 29 2009 11:20 PM
In Topic: blown turbo on ford focus TDCI 2003? 115ps 90,000
29 May 2009 - 11:15 PM
thanks jasmeet,
yes iv cleaned inlet and outlet pipe and intercooler has been washed out (they were dripping in oil)
iv done about 60 miles since, not sure if geting better or not
it seems to struggle at 2000rpm , very juddery , sometimes shaking the car
nobody seems to know the symptoms of a bent conrod or bent valve (thats what garage said it could be)
it idles over ok and is notbad upto 2000 rpm and over 2400 rpm
one day it stalled, then when i started it , i got tons of smoke out of exh so i parked up for the night and iv not had any smoke like that since
In Topic: tdci clatter on start up.
14 May 2009 - 05:20 PM
the mondys are the same i think its just the tdci set up.
Hi mate, exactly same car as mine,tdci 115ps 03 model
mine sounded pretty smooth and no noticable clatter
till turbo blew 3 weeks ago
cheers
10 May 2009 - 10:45 AM
yep they have a cat but you can remove it as it isn't needed for the m.o.t... :)
steve
oh right , thanks mate,
will it eventually burn out or will i need to remove / replace ?
thanks for replys
10 May 2009 - 10:29 AM
Hi mate,
should think when your turbo blew it will have lost oil into the exhaust which may have contaminated your cat which explains why your getting oil droplets from tailpipe..
steve
yes mate, lost about 1 to 2 litres out of exhaust when it happened , but ithought they didnt have a CAT diesles ?
