Member Since 30 Mar 2008
Offline Last Active Jun 17 2009 11:56 AM
Ford CD Radio Loses Signal After 5 Minutes
01 November 2008 - 05:39 PM
I have a problem with my Ford Focus 2002 standard CD/radio.
When you first start the car & put on the radio, it works fine. But 5 minutes later it loses signal.
I have tried putting other aerials on using 3 different Ford Focus aerials & it still remains the same.
Does anyone know a way to fix this problem?
Thanks in advance.
(Ps. The CD player works fine.)
Engine Pulsing when Cold (after cambelt was changed)
27 September 2008 - 07:48 PM
I have a problem with my 2002 focus 1.6 automatic (it has done 88000 miles).
When the engine is cold (once started), it feels as though it is pulsing (wont move forward in a smooth & steady fashion (a bit jerky).
But once over 10mph, it stops unless you go below 10mph & once warmed as well.
I have also noticed that when the interior light is on, that pulses too when the engine is cold.
This only happened once I had my cambelt changed at 75000 miles (noticed it straight away).
The garage that done it, is a very close family friend & they have checked it over since I noticed & said that is looks fine & was a easy job to do with no hitches or mistakes.
I would really appreciate it, if anyone knew what the problem is with it, as the car needs servicing in 1000 miles.
Thanks very much.
