Member Since 19 May 2009
Offline Last Active Nov 30 2009 09:03 PM
In Topic: Noisey Rear Suspention again
02 August 2009 - 07:58 AM
Hi Bobalob when I was in there I found that cable rattle i put a piece of cable tie in there to stop that also the cable was out of its clip behind the heat plate and tapping there, but it hasnt solved my major rattles thanks for help though..cheers cartman690..
02 August 2009 - 07:54 AM
Hi Gaz thanks for the advice bin busy. a recap ive jacked it up and slakened off the 3 bolts each side holding the trailing arms on there is no plate under the chassis to grease re tightened bolts still the same nothing was loose there...(advice?)
I went to ats got them to drive it they checked rear suspention cant find whats doing it said maybe trailing arm bushes but also said ther is no slack in them and also they look uk... they did rule out shocks springs rear bearings etc and said all are ok...
I have since noticed it doesnt do it on wet days, what thats about I dont know! any Ideas welcome cartman690...
In Topic: Air conditioning Charge stub?
02 August 2009 - 07:41 AM
Hi chap the slam panel is the panel above the radiator thats where the high side port is...the port that you want is the low side, behind the drivers side headlight on uk models.best if you havent got all the kit is to get a top up kit from halfords or alike. remove headlight make note of the marks on the bolt washers for refitting alighnment, and follow the destructions on the tin...
mine had lost just a tiny amount and now is still running bfine thanks to the help given on here...
In Topic: Backlash (clonking) while changing gear at low speed
16 June 2009 - 09:55 PM
could it be diff backlash...?
When you get to the bottom of it could you post here please...
14 June 2009 - 09:05 PM
cheers again muddler....
2weeks used every day, still chillin...nice...!!! :lol:
