jdw66
Member Since 30 May 2009
Offline Last Active Sep 20 2009 09:42 PM
In Topic: mondeo fault code p2263
14 September 2009 - 04:00 PM
Your were spot on mate intercooler pipe had a 3 inch split relaced it still smoking but no judders hopefully it will clear after a good run out.Thanks again all !!!!!
12 September 2009 - 11:01 PM
I had the egr and inlet manifold off a few weeks ago and gave them a good cleaning still had juddering and seemed to still be smoking,do you think it could be split in boost pipe from egr to intercooler?. Only 72k with full service history how easy is it to look actuater arm?.Could i have a faulty egr valve?
In Topic: Taking off egr pipe from intercooler
12 September 2009 - 06:56 PM
Had glow plug flashing today found code p2263 turbo boost sytem performance any ideas what this points to? Thanks
In Topic: 2005 Mondeo tdci juddering problem.
02 June 2009 - 04:59 PM
Hi
Thanks for the reply it only does it when i hit about 45-50 mph when im in 4th if i accelerate to say 60-70 it goes away come back down and its there again it lasts up to say 20 seconds. I have noticed i am getting black smoke aswell when i accelerate hard ,took it for a good blast down motorway and up a big hill in 2nd gear loads came away but its still smoking. My milage is 67k always serviced it but to be fair the car is used a lot for short distances so im assuming theres going to be a build up of soot somewhere.I have located egr at the front left of the engine cant see any splits in the large pipe although its hard to get a good look.How easy is it to take egr valve off and give it a good clean? theres only one electrical connector and a few bolts dubilee clip,if i disconnect the electrical connector will it show up light on dash as fault code?(read this somewhere) whats the best way to clean it ,carb cleaner ,soap and water? Thanks for the help
