Aldo
Member Since 04 Jun 2009
Offline Last Active Jul 21 2009 08:31 PM
MOT @ 80,000 MILES
20 July 2009 - 10:32 PM
Just had my MOT done on a 1.8i ford focus 2002 reg with 80,000 miles.
It passed :-)
What I am struggling to understand is the following (I have looked for this info everywhere but can't find it)
MOT print out is :
FAST IDLE TEST PASS
ITEM ........................... ACTUAL ....................................LIMIT
RPM .....................................M.CHECK ...............................2500 - 3000
CO......................................0.00 % ....................................0.20 MAX
HC........................................1 PPM ..................................... 200 MAX
LAMBDA .................................1.00 .......................................0.97 - 1.03
NATURAL IDLE TEST
ITEM .........................ACTUAL .......................[u]LIMIT
RPM.................................M.CHECK...........................450 - 1500
CO..................................0.00 %......................................0.30%
Does this mean the car is producing no CO2 or am I just reading it wrong ?
Gearbox and Engine issues
29 June 2009 - 10:22 PM
Hi All
I am new to this site and wondred if anyone may be able to point me in the right direction.
I own a 1.8 Petrol Focus 2003 Reg.
Unfortuantely recently I have been having the following two issue.
1 - The gearbox ocassionaly gets stuck in gear and in many ocassions I have got stuck at traffic lights due to not being able to release the gear from eg 3rd in to 1st. After 1 - 2 minutes of having the engine switched off the gearbox is perfectly fine and smooth and the problems may not comeback for another 1-2 days.
2 - The cooling fan comes on 10sec after starting the car from cold and keeps kicking in every 2 minutes at 3 to 4 minutes cycles.
I am really not sure where to start looking for the problem :-(
I have even made sure the aircon is off as originaly I thought the fan was linked to that but no luck..
