Support the club!
dgolf
Member Since 12 Apr 2008
Offline Last Active Apr 07 2009 01:06 PM
In Topic: Fiesta Mk4 Diesel leak
21 April 2008 - 09:55 AM
Sorry for the late reply. Got the car back. £375 in total <_<
£95 to rebuild fuel pump
£90 for a new alternator the fuel leak had burned out
Couple of hundred labour and other bits such as oil etc.
Sigh.
In Topic: Wiring for fiesta radio
21 April 2008 - 09:50 AM
Hi All,
Hope someone can help me, I have just got a P reg fiesta for my son, got a new cd player for him as music is so important to him, but unfortunately the previous owner has not only removed the radio, but also the connector, only have a group of wires! Can someone tell me what the leads relate to in a connector as can't afford to go to garage to get them to fit it. Wires I have are:
Thick blue with black stripe,
thick green with black stripe,
a thinner green and black wire,
and 2 thin orange with black stripe
Hope some one can help.
Shaz
Here you go...
Ford Radio Wires
13 April 2008 - 05:29 PM
Hey,
No I don't know the cost yet, picking the car up tomorrow evening so i'll let you know then!
12 April 2008 - 08:19 PM
Hello,
I have/had exactly the same problem. Forgive me for my lack of technical terms but i'm not really that competent with car mechanics!
But anyway, originally my mechanic thought it was a leak from the switch (maybe a solenoid) on the fuel line just where the fuel-cut off for the immobiliser is located. The switch was very hard to get at, taking him all day to remove the reinforced protective cowel. It was changed and it was thought the leak was fixed, however it turns out that it was still apparent. Currently, the injector pump has just came back from getting an overhall/rework and the leak is fixed, allegedly, but i can only tell whenever i get more than 250miles out of a tank!
So, maybe the problem lies with that switch, or if this is a common fault, then it's more than likely something leaking/a loose connection with the pump!
