- → Viewing Profile: Posts: streetka1789
Support the club!
- Group Members
- Active Posts 7
- Profile Views 574
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
street ka
UK/Ireland Location
Please Select
0
Neutral
User Tools
Friends
streetka1789 hasn't added any friends yet.
Latest Visitors
In Topic: C Max Pollen Filter
21 April 2008 - 07:08 PM
hi its in the pass footwell. u need to remove the cover and pull down the fuse box, then you will find a cover with 3, 7mm screws and poss 1, 20 torx depending on weather u have a glove box cooler or not. once this panel is removed u will find the pollen filter, it will take a lot of persuasion to remove, double check all connections on fuse box on install hope this helps
In Topic: KA Thermostat location on a 2003 duratec Engine ???
12 April 2008 - 09:15 PM
right hand side of the head just below rocker cover
In Topic: Ka Air Filter Replacement
12 April 2008 - 09:09 PM
yes yes yes i have put one on mine and all you have to do is buy a breather filter and cut the hose down, otherwise it wont run right and will shoot oil verywhere
hope this helps
hope this helps
In Topic: guarantee..?
12 April 2008 - 09:05 PM
hi i work for ford and they dont cover stonechips and it would only be coverd if you had full service history and all your body and paint check stampped up
- Privacy Policy
Find content
