alright im new to this forum. what it is i jumped in my car other month started engine went to select gear and just felt car move forward as if the clutch isnt connecting properly, i changed the clutch master cylinder and bled the system.after this it was working fine until just now, would you suggest i re bleed the clutch? or has anyone else found that it was actually the clutch. i think it might just be a hydraulic fault. any advice would be much appreciated. cheers! zak
Hey
the same sortof thing happened it me my car just wouldnt work so i done pretty much the same. bled it and change the cylinder it worked for a while but went again so i got a new clutch and seems to have solved the problem
Find content
Not Telling
