When it's cold it over revs till it warms which i belive is normal, the problem is when you rev the engine or if you are in 3rd or 4th and press the clutch to stop at lights the rev counter needle falls below the 800rpm mark and most of the time splutters to a stall.
At first i though the idol was set too low if that was possible but i am now unsure, does any one know what it should be idoling at?
I read in another topic that a guy replaced the idol control valve which helped in his over reving problems could that be the cause of it? and how hard and expensive is that to replace?
Many thanks in advance.
Find content
Male
