Member Since 15 Aug 2009
Offline Last Active Oct 28 2011 08:26 PM
In Topic: X Reg Mondeo Mk3 2Ltr Tddi
21 October 2011 - 11:53 AM
looked there and only the mass senser there
In Topic: Help... Original Radio Code Not Working
10 June 2011 - 07:33 PM
try 1506
In Topic: Gear Box
02 May 2011 - 12:18 PM
hi all.
right im having problems with changing gear from 1st to 2nd im geting a grinding but if i go from 1st then neutral then in to 2nd its fine
its bad when its cold and getts better the warmer she gets but some times is there when warm
do you think this is the clutch or a synchro-ring.
do ford get much problem with there 6 speed box. i now there dmf system is not amazing
thanks for your help
i had this problem in the end i couldnt get any gears it turned out the dmf wanted changing
In Topic: No Power
01 February 2011 - 12:37 AM
have a look to see if the pipe is split. usually if it is u will see or feel what seems to be oil on the outside of the pipe particulsrly close to the egr, i think its because this pipe gets the most flex when the engine tilts on its mounts
checked the pipe it was ok found out it was the egr valve working brill now
In Topic: No Power
31 January 2011 - 12:20 AM
any other symptoms like black smoke?
yes at first but then cleared have been told its the intercooler but needed advise from others first
