carlukeman
Member Since 21 Aug 2009
Offline Last Active Nov 18 2009 10:37 AM
In Topic: Focus 1.8 Duratorq TDCi Engine Layout
23 September 2009 - 10:01 AM
Thanks mintalkin,
I will try to locate this pipe tomorrow in daylight. The problem will be establishing where on the pipe the problem is because the leakage only occurs when the car is running and I give the accelerator a bit of welly. The extra power requirement generates the problem. But thanks for your help.
Kind Regards,
Carlukeman
I just thought I should let you guys know that the problem was a leaking Intercooler Pipe which is now replaced and all is fine. I got the garage to check the "Error Message" that I was getting "Engine Ststems Failure" and they said all is okay now - they lied! Last night when my wife was driving home in the rain she gat the same message, the car ground to a halt and she waited a few minutes and restarted the car - no other warning lights were illuminated. I feel this is an extremely dangerous thing to happen and am going to write to Ford about it. Anyway, I thank you again for your help.
John
12 September 2009 - 06:39 PM
the most common pipe to split is the intercooler pipe, this is the large pipe which is fitted to the bottom of the egr valve. it can also cause black smoke and a loss of power.
Thanks mintalkin,
Kind Regards,
Carlukeman
In Topic: Irritating rear end rattle
28 August 2009 - 12:19 PM
Hi all, thankyou for your replies and its good to know that its not only our car suffering with this annoying rattle, (that meant in a nice way :-) It recntly went in for an MOT and the mechanic said about a problem with the rear right caliper not working properly, but it turned out to be the handbrake cable not functioning on that side so alas we still have our rattle and as its been like itfor so long and the car has done at least 20,000 with the rattle we reckon we have to live with it until the brakes needs doing again and then get the pad carriers changed too.
Many thanks again for your replies and advice.
Hi All,
I thought I should let you all know that I have had my Rattling Ford Focus repaired. The problem turned out to be the hand brake. Six to seven weeks after having my (All round) disc brake pads replaced the car developed a terrible rattle from the rear end. When I applied the brakes the rattle stopped. After a few goes at trying to find the fault, the mechanic at our local garage here in Spain suggested that it might be a missing rubber grommet in the hand brake cable. I explained the other potential solutions given by you guys and he set about the job this morning. I returned after a coffee and the car was waiting for me. The problem was the hand brake and the solution was simple - an adjustment. It turns out the pads were rattling because they were not set at the correct distance. The conclusion; The Brit garage that changed my disc pads were crap, which resulted in 4 visits to the local garage and a lot of wasted time. The good news is, Paco only charged me 15 - what a gem of a guy. Guess where I'll be going in future.
Thanks again Hammie and Coxie,
Regards,
John
23 August 2009 - 10:07 AM
we had this very problem and we replace the pad carryier and the noise has gone
Hi Coxie and Hammie,
Thank you both for your replies. I know the mechanic greased some part in the brake assembly and the noise disappeared for about 30mins and then returned as bad as ever. So, perhaps he used the wrong grease or it might mean he needs to replace the pad carrier. I will let him know of your experiences and again, Thanks.
John
22 August 2009 - 08:21 AM
hi, we have a 2004 1.6 tdc-i c-max with 120,000 on the clock, it has acquired a rather irritating rattle on the rear end somewhere, it happens when you go over bumps and also when your traveling at low speed, it seems to be in time with a wheel turning but when you rest your foot slightly on the brake peddle it goes away :-/, its had new discs and pads, and nothing that can be seen or shaken seems to be loose. i vaughly remember reading an article about a hub problem on some focus's but cannot remember which model or year focus's they were. any advice anyone please ??
My Focus has just developed the exact same problem as you were experiencing. It has been at the local garage 3 times now and the mechanic is pulling his hair out. When I left the garage on Friday, the mechanic told me he was going to contact Ford for advice. If you have mamaged to have your problem fixed, could you please let me know what the problem was and the eventual repair? Like you I had my brake pads changed just 5 or 6 weeks before the rattle appeard and when I apply the brakes it stops. Looking forward to your help.
John
