the 2003 does not have a thatcham approved alarm and immobiliser it has a factory alarm and immobiliser thatcham approved was the rs and st models
- → Viewing Profile: Posts: artscot79
Support the club!
- Group Members
- Active Posts 5,333
- Profile Views 13,391
- Member Title Ford Enthusiast
- Age 34 years old
- Birthday March 25, 1979
Gender*
Male
Ford Model
focus mk2 ti-vct
Ford Year
2006
UK/Ireland Location
Fife
Annual Mileage
0 to 5000
Interests
Classic Cars
General Automotive
Motorsport & Racing
Car Restoration
Car Modification
Travel
Food & Drink
Entertainment
Computers & Electronics
General Automotive -
Previous Fields
Location
cowdenbeath fife scotland
User Tools
Latest Visitors
In Topic: Newly Bought, How Do I Know If It Has It Got Alarm And Immobileser
22 May 2013 - 07:13 PM
In Topic: Engine Treatment At Ford
22 May 2013 - 07:12 PM
indeed it is the stuff they use but they also use the engine flush and flush the engine at the same time still impressive stuff
In Topic: Error Code
22 May 2013 - 06:07 PM
with these faults dont waste money buying a sensor take it to a dealer and have it checked yes youll pay a dealer fee but youll only replace one part instead of replacing half a dozen trying to trace the fault as you see theres many things that can cause the fault
22 May 2013 - 04:43 PM
this should help
ult Code Definition
The Mass Airflow Sensor (MAF)
measures the amount of air entering the engine and the Engine Control
Module (ECM) uses the information to determine the proper amount of fuel
quantity and ignition timing. The P0101 trouble code is set when the
ECM detects a problem in the electrical circuit to the MAF Sensor.
- Mass or Volume Flow Circuit/Performance Malfunction
Symptoms
- Check Engine Light will illuminate
- In some cases, there may be no adverse conditions noticed by the driver
- In other cases, there may performance problems, such as a lack of
power on acceleration, "coughing," misfiring, and/or backfiring - Problems idling
- Black smoke from the tail pipe and poor fuel mileage
- Other codes may be triggered by the Mass Air Flow Sensor problem
such as Oxygen Sensor and/or Fuel Trim Lean/Rich codes (P0130/P0136,
P0131/P0137, P0132/P0138, P0135/P0155, P0171/P0174, P0172/P0175)
Common Problems
- Large vacuum leaks, split Intake Air Boot or PCV Hose, defective intake manifold gaskets
- Mass Airflow Sensor (MAF)
- Mass Air Flow Sensor circuit and or wiring problems
- Defective Barometric Pressure Sensor
- Dirty or contaminated Mass Air Flow Sensing wire or filament
- PCM software needs to be updated
In Topic: What Are These Plugs In Boot For?
21 May 2013 - 07:58 PM
the top black and orange is to add an extra 12v socket in the boot the other two ive no idea mate
- Privacy Policy
Find content
