Member Since 16 May 2008
Offline Last Active Jul 29 2008 07:41 PM
In Topic: pulling left under braking
29 July 2008 - 07:44 PM
very common fault on fords if they are not serviced properly when the pads are renewed ie: copper slip the sliding pins then they do seize or bind causing pulling brakes
In Topic: owners manual
29 July 2008 - 07:40 PM
If you mean the hand book ?? try your nearest Ford dealer as they keep plenty in stock I went to mine and got a full set of books
In Topic: Subframe Bushes??
11 July 2008 - 09:35 AM
Hi yes it can be done by a home mechanic if you know what you are doing . Poly bushes are available and the sub fram alighing tools are available I got mine from Burton Power
In Topic: Air condition Problem
11 July 2008 - 09:31 AM
Just for the record seeing that no one replied I bought a refill kit from Halfords and recharged the system for 40 which included the anti bacterial bomb . System now works great . I was quoted 120 by my local Dealer ???
In Topic: changing inner headlight lenses
11 July 2008 - 09:27 AM
Hi I have replaced both the inner lenses twice now on our 1995 Mk 1 and both times I have done this by removing the top clips and easing the glass forward detaching the inner lenses I had to remove the top clips and the 1 on the inner edge next to the grille takes about 10 mins a side
