H3lly
Member Since 26 Sep 2009
Offline Last Active Oct 07 2013 02:56 PM
#159659 Information About Focus Mkiii?
Posted by H3lly on 05 January 2012 - 11:59 PM
It's all there:
http://www.ford.co.u...sSpecifications
5-seat mode (with mini spare) 316Ltr
5-seat mode (with full-size spare) 277Ltr
5-seat mode (laden to package tray) (with mini spare) 316Ltr
2-seat mode (with mini spare) 1101Ltr
2-seat mode (with full-size spare) 1062Ltr
2-seat mode (laden to roof) (with mini spare) 1101Ltr
2-seat mode (laden to roof) (with full-size spare) 1062Ltr
#156689 Your Focus
Posted by H3lly on 16 December 2011 - 12:23 AM
Mine, recently purchased. I've a few plans in store for here, she's completely stock at the moment. I just fitted climair wind deflectors the other day and some LED bulbs.
1.6i 2003 (130k miles).
#156058 The Ultimate Reverse Bulb 6000Kelvin (55Watt Equivalent)
Posted by H3lly on 11 December 2011 - 11:24 AM
I've attached a 'how to' guide that I nicked from another ford forum. I had planned doing this myself but never got around to it. I need to source the parts needed. Hope this helps.
#148930 Condensation
Posted by H3lly on 17 October 2011 - 11:12 PM
It might be an idea to change your pollen filter. It's located under the glove box to the right of the centre console. There is a letter box type plastic cover that gets unscrewed and the filter is in there. It is a bit awkward to change. If the misting is really bad I would place some silica gel sachets on the dash. If it's like a shower in your car then the dehumidifier would be the best thing for it.
#136667 My First Car.........help Please!
Posted by H3lly on 20 July 2011 - 08:41 AM
Glad I could help out a fellow focus owner :thumbs:.
#136660 My First Car.........help Please!
Posted by H3lly on 20 July 2011 - 08:01 AM
There is no drain plug on the ib5 gearbox and the drive shaft needs to be removed, but I'm not sure if the 1.8 is uses ib5 or mtx75. The blower motor acting up could be a faulty resistor pack. I've attached some pics from a 'how to' guide.
Here is a quick quide on how to change a resistor pack - for rectifying the annoying fan/heater issue, of it only working on speed 4.
This works on Mk1/Mk1.5 - Im not sure on the Mk2.
First thing - Do you find that your fan is working on setting 4, but does nothing on settings 1,2,3? If so, your resistor pack could be at fault, and is simple and cheap to repair.
Step 1 - Order a new Resistor pack from ford - Part No 1311115, priced at 9.95+VAT = (11.69).
Step 2 - Empty your glove box, and drop.
In the pic below, you will see a bar to the left that locks in to the face of the glove box (see red box). Unclip this, then push in the side walls of the glove box to release it the rubber stoppers (see green box), this will allow the glove box to be dropped fully.
NOTE - My Mk1 doesnt have the bar (red box), where my Mk1.5 does.
If you look in the space to the rear right, you will see the resistor pack (the blue rectangle thing at the back).
Step 3 - Release the cable clip, and undo the screw at the bottom (just below the cable clip) I had to use a long handled screw driver. Make sure you dont drop the screw.
Step 4 - Take your new resistor pack, connect the wires and screw back in place
New Resistor Pack - Front
New Resistor Pack - Back
New Pack fitted
Step 5 - Test your heater/fan control speed dial.
Thats it - It took me no more than 5 mins to do.
#123461 How To Fit New Front Lower Grill On Mk2.5 Focus
Posted by H3lly on 19 April 2011 - 12:37 AM
Looks very tidy, matches the upper grill very well. Good write up.
#100360 Mk1 1.6 Battery Light Come On Today And Stayed On Please Advice Me
Posted by H3lly on 09 October 2010 - 12:08 AM
Do you do short distances or does she get some motorway use.
#95825 Headlight Removal
Posted by H3lly on 03 September 2010 - 12:21 PM
I just wriggled under there to remove the lower screw. No need to remove wheels or arch liners. More info on this job here.
  • DAS likes this
