Member Since 19 Oct 2009
Offline Last Active Aug 02 2015 02:35 PM
#326194 Scratched Alloys :-(
Posted by AdamC11 on 26 January 2014 - 07:07 PM
That's the cheapest quote that I know of.
If you know anybody who works in a bodyshop, they could probably do it cheaper than that.
#326188 Scratched Alloys :-(
Posted by AdamC11 on 26 January 2014 - 06:56 PM
Hi sazaboo,
That's not too bad.
You are probably looking at £60 a corner for a refurb. :)
#279934 Removing Rear Wiper
Posted by AdamC11 on 04 August 2013 - 06:21 PM
Hi Stuart
I have dewipered my car today.
It is really simple.
Remove the two side trims off either side of the boot by unscrewing the two screws that secure them in.
Then unscrew the screw in the tailgate handle.
Gently pull away the plastic trim, don't worry if it cracks and bangs, its ok
You will then be left with all the motor and wiring showing.
There are three bolts holding the motor in, unscrew these and gently separate the wiper from the motor.
I used two grommets, one inner and one outer.
Inner is a 19mm grommet
Outer is 24mm grommet, but im currently looking for a better one.
Hope this helps?
#279921 Rear Wiper Hole On Boot
Posted by AdamC11 on 04 August 2013 - 05:29 PM
Hi Guys,
Just a question.
If you were to remove the rear wiper what is the best size of blanking grommet to use to cover up the hole?
Thank you
#279571 Numberplate Bulbs
Posted by AdamC11 on 03 August 2013 - 11:26 AM
Hi Guys,
Im looking to upgrade my numberplate bulbs to led's.
Can anybody advise which ones are the best.
Thank you
