Varies, depending who you go to. £250-£350 all in. I've no idea what Ford charge but there's no need to used main agents if you don't want to pay through the nose. The job is straightforward and genuine or patterned parts readily available
- → Viewing Profile: Posts: flying clutchman
Support the club!
- Group Members
- Active Posts 99
- Profile Views 1,024
- Member Title Settling In Well
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
transit2.5D
UK/Ireland Location
Please Select
User Tools
Friends
flying clutchman hasn't added any friends yet.
Latest Visitors
In Topic: Clutch Squeal When Moving Off
24 May 2013 - 12:24 PM
24 May 2013 - 12:16 PM
The 1.6 petrol doesn't have a dmf so no need to worry about it. The squeal is caused by the clutch disc glazing ( general wear and tear) and used to affect escorts quite badly. It's not a sign of anything worse happening. If it gets on your nerves too much changing the clutch will cure it.
In Topic: Gearbox Oil Leak On 1998-2004 Focus
19 May 2013 - 11:28 PM
That's what it looked like at first sight. You'll just need a new gasket for the end cover
14 May 2013 - 12:27 PM
Well, it's a possibility as the fluid is red. Mk1 Focus gear oil is not normally red, but sometimes people put it in. You could try getting it steam cleaned then look to see where the fresh oil is coming from
13 May 2013 - 03:42 PM
I've seen a few focus leak from here. I've never changed one of these seals but I think you could remove the knuckle on the end and then prise out the old seal. You can easily check, just unclip the front cover and look at the bottom selector.
- Privacy Policy
Find content
