yunii Posted March 21, 2018 Share Posted March 21, 2018 Has anyone done this ? I have ordered rear axle's left & right side calipers / Discs beam from 1.8tdci . Can i just fit the entire beam with all attached or not. Do i use my stock abs sensor or one on beam work ?Anything else apart from handbrake cable & brake hoses needed ?Any hint / tips or ideas welcome .Btw my car has drums. Yunii Sent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 21, 2018 Share Posted March 21, 2018 You don't need a rear axle. The parts simply bolt on. Quote Link to comment Share on other sites More sharing options...
zain611 Posted March 21, 2018 Share Posted March 21, 2018 38 minutes ago, stef123 said: You don't need a rear axle. The parts simply bolt on. Is this true? What about on the mk6 fiestas as I actually am looking at getting a rear ST disc beam very soon. Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 22, 2018 Share Posted March 22, 2018 13 hours ago, zain611 said: Is this true? What about on the mk6 fiestas as I actually am looking at getting a rear ST disc beam very soon. Does the mk6 not use the same/similar set up to the mk1 focus, swap the stub axles for disc ones. Quote Link to comment Share on other sites More sharing options...
zain611 Posted March 22, 2018 Share Posted March 22, 2018 The fiesta beam is all in one for both sides not like the focus which has independent suspension. I did ask my dad about this (as he does the main mechanic work 😂) and he said it may cost more to get the hubs, handbrake cable, splash shield etc separately compared to just getting the beam which has just about everything on it. Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 22, 2018 Share Posted March 22, 2018 44 minutes ago, zain611 said: The fiesta beam is all in one for both sides not like the focus which has independent suspension. I did ask my dad about this (as he does the main mechanic work 😂) and he said it may cost more to get the hubs, handbrake cable, splash shield etc separately compared to just getting the beam which has just about everything on it. Strip everything off it though and use the parts. Saves faffing about dropping the rear beam when your working on the floor. im pretty sure the stub axles and stuff are the same for them both, I might be wrong. 1 Quote Link to comment Share on other sites More sharing options...
