Front end knocking
I have a M7 1.4TDI which has developed a knocking when turning right over any uneven road surface. Occasionally does it on the straight too.
As I drive over bumps in the while turning I hear a few metal on metal sounding knocks sounding from off side front.
Any ideas what I should be looking for or checking first?
Thanks Mike
Hi there first thing to check would be droplinks/anti rollbar links on the front as that's what happens when they wear down.
Sent from my SM-N950F using Tapatalk
Thanks, I was thinking perhaps drop links.
drop links are only 8 quid each, make sure your car is jacked up even on both sides on axle stands
Drop links or springs would be my guess
I would have put good money on this being on off side of car, as I was definitely sure that's where the nocking was coming from.
Turned out to be the nearside ball joint !
