JoBoy99 Posted April 19, 2018 Share Posted April 19, 2018 Hi, Can anyone point me in the right direction of the right bits I need to be able to run forescan. I'd like to do a few things like make the windows go down with the key and stuff like that I have heard you can do with it. Any help is great cheers Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted April 19, 2018 Share Posted April 19, 2018 The windows should go down anyway with the key, it just needs setting up in most cases. You need a modified Elm327 adaptor (has a little switch on the obd2 plug). The recommended one is from Tunnelrat as other ones from eBay are probably cheap Chinese copies. Obviously then a laptop with Forscan installed with extended license (free, you just have to renew it every two months). Quote Link to comment Share on other sites More sharing options...
JoBoy99 Posted April 20, 2018 Author Share Posted April 20, 2018 7 hours ago, Luke4efc said: The windows should go down anyway with the key, it just needs setting up in most cases. You need a modified Elm327 adaptor (has a little switch on the obd2 plug). The recommended one is from Tunnelrat as other ones from eBay are probably cheap Chinese copies. Obviously then a laptop with Forscan installed with extended license (free, you just have to renew it every two months). Does the software for it work with Mac or is it windows only? Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted April 20, 2018 Share Posted April 20, 2018 1 hour ago, JoBoy99 said: Does the software for it work with Mac or is it windows only? Windows only Quote Link to comment Share on other sites More sharing options...
JoBoy99 Posted April 21, 2018 Author Share Posted April 21, 2018 On 20/04/2018 at 6:53 AM, Luke4efc said: Windows only Got it all and the software, any tips on how to do the window thing? Quote Link to comment Share on other sites More sharing options...
