Leaf Springs in Rangers - All compatible?
Hi all,
Can anyone tell me if the leaf springs from a 2008 Ford Ranger Wildtrak would fit a 2000 Ford Ranger 4x2 Supercab? The wheelbase is the same length 3220mm, but not sure if tyhere is anything else I need to take note of.
Any help most appreciated.
  • 3 months later...
You also have to take into account spring rate, which varies depending on option pack.  My opinion is if you replace both rear springs it doesn't really matter, but it will matter a lot if you only change one spring.  You should also look at thickness of the leaves, because you don't want to put a weaker spring on than you started with.
