Hughes1208 Posted May 2, 2018 Share Posted May 2, 2018 I'm trying to hardwire in a dashcam and was wondering which fuses under the glovebox are permanent live as I don't have a multimeter to check. Thanks Quote Link to comment Share on other sites More sharing options...
Eddieboi Posted May 2, 2018 Share Posted May 2, 2018 I'm trying to hardwire in a dashcam and was wondering which fuses under the glovebox are permanent live as I don't have a multimeter to check. ThanksIf you have a cig socket normally that’s a perm live. I have my thinkware F900 pro hardwire to the cig socket fuse as perm live. You can check by putting in a cig usb charger socket into it and seeing if you can charge your phone whilst engine is off. My one has a light that turns on when I connect it into the cig lighter socket. Sent from my iPhone X using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
lst Posted May 2, 2018 Share Posted May 2, 2018 I think I remember reading the accessory sockets (cig) only stay live for 75 mins after ignition is turned off. Looking at the fuse chart, I would guess that fuse no.5 lock/unlock would be live at all times, but that's only a guess without checking.. Quote Link to comment Share on other sites More sharing options...
lst Posted May 20, 2018 Share Posted May 20, 2018 Just to confirm, I've now hard wired my dashcam, and fuse no.5 is permanently live 👍 Quote Link to comment Share on other sites More sharing options...
DJFern94 Posted May 20, 2018 Share Posted May 20, 2018 3 hours ago, lst said: Just to confirm, I've now hard wired my dashcam, and fuse no.5 is permanently live 👍 Did you go for single or dual dashcam? And has it effected the start /stop? Quote Link to comment Share on other sites More sharing options...
lst Posted May 20, 2018 Share Posted May 20, 2018 Just a single dashcam, a nextbase 512g that I've had a couple of years. Start/Stop works fine for me, but It's probably too early to say if it affects start/stop, but will definitely keep and eye on that. 1 Quote Link to comment Share on other sites More sharing options...
MasonJY Posted May 12, 2023 Share Posted May 12, 2023 On 5/20/2018 at 1:40 PM, lst said: Just to confirm, I've now hard wired my dashcam, and fuse no.5 is permanently live 👍 any issues with this? i have a Nextbase 522GW that i would like to use the parking mode with Quote Link to comment Share on other sites More sharing options...
