JoBoy99 Posted May 12, 2018 Share Posted May 12, 2018 Ever since I’ve got my car I’ve noticed that when I’m in first gear, (sometimes others, but mainly first), when I press the clutch to change gear the revs keep increasing, this isn’t due to the throttle being pressed as i even come completely off it and nowhere near it to ensure it isn’t my foot, but the revs keep on increasing up to around 3/4K revs. anybody got the same? Is it normal or is it an issue? cheers Quote Link to comment Share on other sites More sharing options...
doggsbody Posted May 13, 2018 Share Posted May 13, 2018 16 hours ago, JoBoy99 said: Ever since I’ve got my car I’ve noticed that when I’m in first gear, (sometimes others, but mainly first), when I press the clutch to change gear the revs keep increasing, this isn’t due to the throttle being pressed as i even come completely off it and nowhere near it to ensure it isn’t my foot, but the revs keep on increasing up to around 3/4K revs. anybody got the same? Is it normal or is it an issue? cheers Its sucking air in or a possible collapsed pipe that's being sucked together or splitting, check all pipe's are tight non are very soft, most commonly the emmisions pipe depending upon the engine it'll either be a T shape piping at the front or at the back of the engine and comes round the side, they normally split or go soft due to the heat 👍 Quote Link to comment Share on other sites More sharing options...
