Ryan_Tango Posted May 12, 2018 Share Posted May 12, 2018 Hi all, my mums 2009 Mondeo MK4 has developed a strange noise (I tried to capture it on video but it won't pick it up but is very present) it sounds like a wheel bearing but that has been replaced the mechanic has had pretty much the whole car apart and can't find anything, it's a strange rumbling sound that the noise stays the same regardless of speed, anyone have any ideas? Thank you. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 12, 2018 Share Posted May 12, 2018 Exhaust catching on the body, rear box is often the culprit, broken mount could be the cause, check the mounts Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted May 13, 2018 Author Share Posted May 13, 2018 12 hours ago, pragmatix said: Exhaust catching on the body, rear box is often the culprit, broken mount could be the cause, check the mounts Thank you will get that checked out, is there anything else it could be in the case it's all good? Quote Link to comment Share on other sites More sharing options...
