Mk6 fiesta electric window fault
Hi there! Recently my mk6 fiesta electric windows have stopped working. I have checked the 30 amp fuse and that was fine. Then i checked if there was power to the switch and there wasnt! So now i have come to a dead end and cannot think of what it could be.
If anyone has any suggests please let me know. Thanks
wire broken inside the cable where it goes from door post to the door?  if you wiggle that cable about can you get it to work monentarily?
I just tried that and still nothing! Plus its both the n/s and o/s windows that arent working. So im not sure if there is a control unit which communicates with both sides.
I don't know if there is a control unit . As the passenger window can be controlled by a switch on the drivers door I can see a fault in the wiring for drivers door stopping both windows possibly. I think you need a wiring diagram really. I can't offer any more suggestions as i don't know enough about it
Is there power across the fuse or did you just visually check it?
Does your door closed sensor work?  Is there power at the NS switch?
