Jollyandy Posted August 21, 2019 Share Posted August 21, 2019 There’s now an option to enable/disable engine sound effect on Sync 3 in the newest update of Forscan.Sent from my iPhone using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
Daggerit Posted August 21, 2019 Share Posted August 21, 2019 I wonder if there's also options for what sound it generates, as well as just being able to turn it on and off? I fancy my Ecoboost sounding like a big V8 inside the cabin... 😂 Quote Link to comment Share on other sites More sharing options...
ElliotReid Posted August 21, 2019 Share Posted August 21, 2019 Ford should make it that if you change the setting in Forscan it sounds like Joe Pasquale making engine noises. 2 Quote Link to comment Share on other sites More sharing options...
Chancee Posted August 21, 2019 Share Posted August 21, 2019 Can anyone test engine sound enhancement in ST Line? Thanks. Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted August 21, 2019 Share Posted August 21, 2019 Is that enabled as standard I wonder on an ST Line X? I do find mine quite noisy, I'd happily switch it off. Quote Link to comment Share on other sites More sharing options...
Daggerit Posted August 21, 2019 Share Posted August 21, 2019 10 minutes ago, Guy Heaton said: Is that enabled as standard I wonder on an ST Line X? I do find mine quite noisy, I'd happily switch it off. Doubt it, I find if I have any music on at all I can't hear mine! Quote Link to comment Share on other sites More sharing options...
Martijn89 Posted August 26, 2019 Share Posted August 26, 2019 Anyone tested it out yet? I hope to give it a try sometime soon! Would it affect sound quality? Wouldn't really be happy ruining the B&O sound in exchange for a more sporty "engine" sound. Quote Link to comment Share on other sites More sharing options...
Da9L Posted August 27, 2019 Share Posted August 27, 2019 I've just ordered a cable for this and I'm quite excited to see if it even works on my Fiesta Mk8 at all since i have that wierd Sync "2.5" version on it. Quote Link to comment Share on other sites More sharing options...
JordanJ33 Posted August 29, 2019 Share Posted August 29, 2019 On 2/13/2019 at 5:17 PM, Dediostarrak said: I bring bad news 😓 We have installed the switch with the CC button and we have activated the CC option in the forscan. (The latest version) Once we have done everything, we have gone to try it. As you can imagine from the first sentence, it has not worked. It is not that the DC button does not work, none of the left switch buttons work. (limiter, volume up, volume down and mute volume) Is it possible that some fuse is missing by putting? When passing through a tunnel, the blue light from the bottom of the buttons did turn on. @Martijn89 Could you send, if it's not too much trouble, a picture of your fuses? I seemed to see that your car had the CC installed. Thanks in advance. On 2/13/2019 at 5:17 PM, Dediostarrak said: I bring bad news 😓 We have installed the switch with the CC button and we have activated the CC option in the forscan. (The latest version) Once we have done everything, we have gone to try it. As you can imagine from the first sentence, it has not worked. It is not that the DC button does not work, none of the left switch buttons work. (limiter, volume up, volume down and mute volume) Is it possible that some fuse is missing by putting? When passing through a tunnel, the blue light from the bottom of the buttons did turn on. @Martijn89 Could you send, if it's not too much trouble, a picture of your fuses? I seemed to see that your car had the CC installed. Thanks in advance. Hi, you have to go to the SSCM Module in forscan to change the part number for the left hand buttons. Once that’s done all should work normally. I have done this and it works. Quote Link to comment Share on other sites More sharing options...
KdR Posted September 11, 2019 Share Posted September 11, 2019 Has anyone turned off start & stop on a fiesta st line of 2018? What codes did you use? Quote Link to comment Share on other sites More sharing options...
Da9L Posted September 20, 2019 Share Posted September 20, 2019 I just got my cable and tried out something basic like enabling trafic sign recognition in the IPC module, and even though i can see in my dashboard screen that two circles have shown up in the right bottom corner, they dont seem to actually recognize signs in any way. I have lane assist and and adaptive cruise control, so i assume this should be enough ? Also, what has people actually been able to get to work using forscan on our fiesta ? Quote Link to comment Share on other sites More sharing options...
Martijn89 Posted September 23, 2019 Share Posted September 23, 2019 On 9/20/2019 at 11:54 PM, Da9L said: I just got my cable and tried out something basic like enabling trafic sign recognition in the IPC module, and even though i can see in my dashboard screen that two circles have shown up in the right bottom corner, they dont seem to actually recognize signs in any way. I have lane assist and and adaptive cruise control, so i assume this should be enough ? Also, what has people actually been able to get to work using forscan on our fiesta ? I think a third camera is used for that, aimed specifically at the side of the road. When I look at my Fiesta, I have 3 camera's/sensors mounted. But I'm not sure so maybe you can activate it. Forscan is fun, but there are not so many things you can configure. What I did or tried: - Autolock, locking my car when I start driving. - Sync 3 splash screen, it shows the ST screen when I start the car. - Tried: rear lights always on, never got it to work. Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted September 23, 2019 Share Posted September 23, 2019 On 8/21/2019 at 10:29 AM, Jollyandy said: There’s now an option to enable/disable engine sound effect on Sync 3 in the newest update of Forscan. Sent from my iPhone using Tapatalk Pro AWESOME!!! Can't wait for my elm lead to come, so I can disable this. Quote Link to comment Share on other sites More sharing options...
DG97 Posted September 23, 2019 Share Posted September 23, 2019 2 hours ago, Martijn89 said: I think a third camera is used for that, aimed specifically at the side of the road. When I look at my Fiesta, I have 3 camera's/sensors mounted. But I'm not sure so maybe you can activate it. Forscan is fun, but there are not so many things you can configure. What I did or tried: - Autolock, locking my car when I start driving. - Sync 3 splash screen, it shows the ST screen when I start the car. - Tried: rear lights always on, never got it to work. How did you get the ST splash screen? Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted September 23, 2019 Share Posted September 23, 2019 How did you get the ST splash screen?It’s in the APIM menu; btw [mention=94045]Martijn89[/mention] where did you find the LED signature setting please? Sent from my iPad using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
KdR Posted September 25, 2019 Share Posted September 25, 2019 On 9/23/2019 at 4:29 PM, Jollyandy said: It’s in the APIM menu; btw [mention=94045]Martijn89[/mention] where did you find the LED signature setting please? I dont have APIM, where can i enable it? Quote Link to comment Share on other sites More sharing options...
Da9L Posted September 26, 2019 Share Posted September 26, 2019 On 9/23/2019 at 1:48 PM, Martijn89 said: I think a third camera is used for that, aimed specifically at the side of the road. When I look at my Fiesta, I have 3 camera's/sensors mounted. But I'm not sure so maybe you can activate it. Forscan is fun, but there are not so many things you can configure. What I did or tried: - Autolock, locking my car when I start driving. - Sync 3 splash screen, it shows the ST screen when I start the car. - Tried: rear lights always on, never got it to work. My fiesta doesn't have Sync 3.. Its rather wierd, but its listed as Sync 2.5. So i guess the splash screen is not an option for me. Can you take a picture of your sensors ? It would be a good reference for the future, so people can compare their camera setup. I managed to also active a Ford Performance option in my small dashboard screen, but that didn't really do anything, other than enabling a red themed digital speedometer option. I also managed to disable the temperature gauge in the same small dashboard screen, but i re-enabled it again. I was hoping i could find some way to instead show a clock there, since my Sync main screen doesn't show the time when in Android Auto. Another thing that seems to work, and i actually like, is i disabled the sound chimes which is always being spammed at you when the car is turned on. I set it to Single instead of Multi, and this is completely disabled all the sound chimes though. Have to look further into it. Quote Link to comment Share on other sites More sharing options...
DEVSR2 Posted September 26, 2019 Share Posted September 26, 2019 55 minutes ago, Da9L said: My fiesta doesn't have Sync 3.. Its rather wierd, but its listed as Sync 2.5. So i guess the splash screen is not an option for me. Can you take a picture of your sensors ? It would be a good reference for the future, so people can compare their camera setup. I managed to also active a Ford Performance option in my small dashboard screen, but that didn't really do anything, other than enabling a red themed digital speedometer option. I also managed to disable the temperature gauge in the same small dashboard screen, but i re-enabled it again. I was hoping i could find some way to instead show a clock there, since my Sync main screen doesn't show the time when in Android Auto. Another thing that seems to work, and i actually like, is i disabled the sound chimes which is always being spammed at you when the car is turned on. I set it to Single instead of Multi, and this is completely disabled all the sound chimes though. Have to look further into it. Are you able to show a picture of the ford performance screen please? @Da9L Quote Link to comment Share on other sites More sharing options...
Da9L Posted September 26, 2019 Share Posted September 26, 2019 1 hour ago, DEVSR2 said: Are you able to show a picture of the ford performance screen please? @Da9L I will do that later today :) Quote Link to comment Share on other sites More sharing options...
DEVSR2 Posted September 26, 2019 Share Posted September 26, 2019 Thanks @Da9L, interested to see what it looks like! Quote Link to comment Share on other sites More sharing options...
Da9L Posted September 28, 2019 Share Posted September 28, 2019 Hi, sorry for the late response! Have been quite busy the last days. Heres som pictures 🙂 1 1 Quote Link to comment Share on other sites More sharing options...
DEVSR2 Posted September 28, 2019 Share Posted September 28, 2019 Thanks @Da9L! The setup looks cool. Do you always have yours on? Any issues or functionality which doesn't work? Quote Link to comment Share on other sites More sharing options...
Da9L Posted September 29, 2019 Share Posted September 29, 2019 On 9/28/2019 at 5:35 PM, DEVSR2 said: Thanks @Da9L! The setup looks cool. Do you always have yours on? Any issues or functionality which doesn't work? No i actually dont use it like that. Mine is always on the trip computer, with mileage and distance before empty etc. 🙂 Quote Link to comment Share on other sites More sharing options...
Da9L Posted September 29, 2019 Share Posted September 29, 2019 On 9/23/2019 at 1:48 PM, Martijn89 said: I think a third camera is used for that, aimed specifically at the side of the road. When I look at my Fiesta, I have 3 camera's/sensors mounted. But I'm not sure so maybe you can activate it. I tried activating it, but it doesn't recognize any signs. But i have all the options inside the menus to enable it etc. Can you maybe snap a picture of how your cameras/windshield look ? Then i can compare it to mine 🙂 Quote Link to comment Share on other sites More sharing options...
Chancee Posted September 29, 2019 Share Posted September 29, 2019 On 9/28/2019 at 2:45 AM, Da9L said: Hi, sorry for the late response! Have been quite busy the last days. Heres som pictures 🙂 Very nice. Thank you. Could you try the option "engine sound enhancement" and see if it works? It should fill the engine sound by playing it through the speaker system. This would be very helpful. Quote Link to comment Share on other sites More sharing options...
