Boswell Posted June 6, 2018 Share Posted June 6, 2018 The air con is not working on 04 fiesta. Went to re-gas and found it to be full. Noticed compressor isn't running. It could be one of the wires gone but I noticed the relay box only has one in it. It seems to be the air con relay yet the heating works and air con doesn't. Any ideas if that is the relay and where can I get new ones? Also, the fans only work on max - 4. And the others dont do anything, might be unrelated. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 7, 2018 Share Posted June 7, 2018 Does the cooling fan work? I doubt you'll have a PTC heater in a UK Fiesta so wouldn't expect relays in there but you will need the fan to work for the AC. The interior blower needs a new resistor which is why it only works on max setting, unrelated to AC issue. Quote Link to comment Share on other sites More sharing options...
Boswell Posted June 7, 2018 Author Share Posted June 7, 2018 9 hours ago, TomsFocus said: Does the cooling fan work? I doubt you'll have a PTC heater in a UK Fiesta so wouldn't expect relays in there but you will need the fan to work for the AC. The interior blower needs a new resistor which is why it only works on max setting, unrelated to AC issue. Thanks, replacing that resistor now. Haven't had chance to get the engine hot enough for the fan yet. Quote Link to comment Share on other sites More sharing options...
