Sign in to follow this
Russ 6334
sierra cosworth 4x4 speedo cable
hi all, just picked up a sierra cosworth 4x4 K plate with 69k miles!
driving it down the motorway the speedo was fine then jumped around a bit and hit zero, i suspect the cable is loose or snapped etc, anyone know where it is in the gearbox?
thanks
Never had a Cosworth but had a 1990 Sapphire.
You should be able to find where it goes through the bulkhead to the speedo, just follow it down to the gearbox. Probably worth checking that it hasn't come loose from the back of the speedo too.
I also have a 4x4 sierra sapphire Cosworth
check out chrisfix on YouTube
he has many techniques on how to change wiring and check if it is broken
  Only 75 emoji are allowed.
