Rookie Kenwood KSC SW11 install issues!
Hi all,
unsure if if this is the right sub section of the forum but here goes........
Struggling with the above sub install in my no 7.5 fiesta. I went with Paramanic’s guide as follows:
...........and ended up with this:
https://m.imgur.com/gallery/9NHSv61
when I try to launch everything is fine but volume stuck at zero. Sub has power (blue light on controller). Also worth noting if I use the WAMO clips to reside back to normal it all works fine again on the stock system.
I tried first without the WAMO clips, I.e. bullet connectors per Paramanic’s guide and then with........ same thing happens either way.
At a complete loss for why this won’t work for me, any ideas?
worth noting I accidentally cut the wrong of two white/browns — one has a thick (wrong) and the other a thin (correct) brown line........... assume not an issue because it all works fine if I revert to stock wiring as mentioned .
any suggestions?
