Phil3747 Posted February 1, 2021 Share Posted February 1, 2021 馃憤 Quote Link to comment Share on other sites More sharing options...
Bol Posted March 17, 2021 Share Posted March 17, 2021 Hi is this recommended for 1.0 125ps? https://mag1.com/products/passenger-car-motor-oil/full-synthetic-motor-oil/mag-1-full-synthetic-5w-20-motor-oil/ The engineer said that it meets requirements. 聽 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 18, 2021 Share Posted March 18, 2021 This oil does not meet the Ford WSS-M2C-948-B specification that is required for the 1.0 ECOboost. It is not recommended to use this oil in.聽聽 1 Quote Link to comment Share on other sites More sharing options...
Bol Posted March 18, 2021 Share Posted March 18, 2021 Could it harm the engine? Should it be changed as soon as possible or next time? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 18, 2021 Share Posted March 18, 2021 On a 1.0 ECOboost you should never use an oil type that does not meet the required聽WSS-M2C-948-B specification. The 1.0 ECOboost has a wetbelt (timing belt inside the engine that runs though the oil). The聽WSS-M2C-948-B specification oil was specifically developed for this聽wetbelt engine and does not affect the material of the wetbelt.聽 Every other oil type that does not meet the聽WSS-M2C-948-B specification can聽(and usually will) affect the material of the wetbelt and cause premature wetbelt failure. Because of the exact same reason it is not allowed to perform an engine flush on the 1.0 ECOboost engine. If an incorrect oil specification has been used on a 1.0 ECOboost engine it is highly recommended to replace the wetbelts. 聽 2 Quote Link to comment Share on other sites More sharing options...
Bol Posted March 18, 2021 Share Posted March 18, 2021 So better to change it. But could it harm the engine until next time? 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted March 20, 2021 Share Posted March 20, 2021 On 3/18/2021 at 9:46 AM, Bol said: So better to change it. But could it harm the engine until next time? How many times does @JW1982聽have to say it , if you put the wrong specification oil in your particular engine it will affect the (wet) timing belt integrity.聽 If the belt fails it's goodbye engine, so YES it聽'could' and very likely WILL harm your engine! 聽 Change the oil and filter as soon as possible and hope it hasn't already damaged the timing belt. 3 Quote Link to comment Share on other sites More sharing options...
Bol Posted March 21, 2021 Share Posted March 21, 2021 Changed the oil with Castrol magnatec, not the oil filter. 2 Quote Link to comment Share on other sites More sharing options...
VFR800 Posted March 21, 2021 Share Posted March 21, 2021 Engine oil posts are better than watching YouTube!!! I swear oil manufacturers and Catholic priests all went to the same school!! 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted March 21, 2021 Share Posted March 21, 2021 6 hours ago, Bol said: Changed the oil with castrol magnatec, not the oil filter. No, for christ's sake.聽 If you're changing the oil, change the fking filter as well!聽 #IGiveUp 3 1 Quote Link to comment Share on other sites More sharing options...
Bol Posted March 22, 2021 Share Posted March 22, 2021 Don't be rude. Thank you all for the advice. Quote Link to comment Share on other sites More sharing options...
Kenny_stline Posted April 1, 2021 Share Posted April 1, 2021 Edit wrong section sorry聽 Quote Link to comment Share on other sites More sharing options...
Jurgis Posted April 20, 2021 Share Posted April 20, 2021 What do you think about 100proc. synthetic engine oil? Do the RED LINE 5W20 is harmles for 1.0 ecoboost? I am also thinking over thiker oil like extreme a.m.g 5w30 . The reason is that it's made of PAO and esters. Quote Link to comment Share on other sites More sharing options...
YOG Posted April 20, 2021 Share Posted April 20, 2021 5 hours ago, Jurgis said: What do you think about 100proc. synthetic engine oil? Do the RED LINE 5W20 is harmles for 1.0 ecoboost? I am also thinking over thiker oil like extreme a.m.g 5w30 . The reason is that it's made of PAO and esters. Does RED LINE 5W20 meet聽Ford WSS-M2C948-B? If YES, you can. If NO, you shouldn't. Quote Link to comment Share on other sites More sharing options...
