Phil21185 Posted June 24, 2018 Share Posted June 24, 2018 Ok, so this thread is intended to be a collaboration between those of us who are happy to tinker and to see what can be achieved. Primarily this information relates to Sync 3, but some of it applies to Sync 2. Please note that you require an ELM327 interface and Forscan with an extended licence to attempt any of this, and none of the contributors to this thread will be held responsible if you screw something up, though I'm sure there will be plenty of help available if you do. People, I'm posting up here the plain text configuration of my personal Sync 3 APIM, along with the As-Built in hex format (as seen in Forscan). What I'm hoping is that with enough research (a lot of which has been done by people on the F150 forums), and with enough collaboration, we can cross reference differences between plain text and as-built configs, and basically datamine the APIM so that it will be fully customisable. I intend to attach a spreadsheet with columns for each plain text option, the corresponding byte in the as-built, and possible values. Firstly: GOLDEN RULE: ALWAYS DO A BACKUP OF YOUR SETTINGS BEFORE FIDDLING!!! Accessing APIM Config: Hold next track and eject for several seconds. Car will perform speaker test, then diagnostics menu will appear. APIM config is in here. There is a lot of info, so feel free to post pictures instead of typing it out! Ok, to get the ball rolling is the plain text config for my APIM. This is typed out exactly as shown, including missing values and spelling errors: Smart DSP: Do Not log missing dsp messages AAM: Do not log SDARS: Do not log mising sdars (ACM) RSEM: do not log PDC HMI: Off Rear camera RVC Not PResent illumination: FoE strategy Extended play: on EPT: 60mins (FoE) Clock Master: BCM (C1CMA and CGEA 1.3) 10 Minute Clock: Disabled (ALWAYS Disabled) Can Steering Wheel Control Switches: N/A (do not log missing messages - also HW SWC) Aux in: Audio Only Climate Control: C1CMA - Euro Strategy Chime Strategy: European Type of Volume Knob: Rotary Fader in sound menu: Fader in sound menu Android Auto Projection Mode Aux Input: Disabled Bass/Mid.Treble settings: universal for audio modes Ignition type: Push Button Start Tuner Type: Dual Tuner or Single Tuner + data tuner Vehicle Driver Location: Right HAnd Drive (When user selectsDriver HMI button, send passenger occupancy mode can signal) WOW seat: Not Present TMC: Available (enable TMC menu) DAB: Available Climate Front Zones: Dual Zone Steering Wheel Angle Sensor: Absolute HD RAdio: Not Available ICAN Diagnostics: On Smart Auto (Climate): Disabled My Temp: Not available Radio Tuner Market: RDS MArket (Europe, APA, SA) Rear Climate: Not avail Heated Steering WHeel: Not avail Heated Seats HMI: None (Hard Buttons or no heated or cooled only) Brand: Ford Hybrid (HEV): Not a hybrid (hev) vehicle Microphone 2: Not present (Disable Mic2 Functionality) USB2 Not Present (usb2 HMI will be disabled) NAv App: Nav App turned off REFP (Rear EPF with rotary knob): available SD Slot: SD SLot Present Display Speed limit in HMI (traffic sign recognition installed): Speed Limit no in HMI Start Stop Vehicle: Non Start Stop Transmission Type: Manual ECALL: European Strategy (0x4A message) Non-Metric units for nav: Miles/yards Ambient Lighting: available (ambient lighting menu button shall not be displayed) Door Keypad Code: Not available (door keypad menu buttonshall not be displayed) Fuel Type: Gasoline HW SWC: Not available Mode Man Icon (Climate):enabled Climate Control Type: Automatic Surround sound available in occupancy mode: Not available Nav Repeater Format: Intel Format PHEV: NA Recirc Icon (Climate): Disabled Ford Works: NA Front Camera: NA DM6 HMI: Off Number of Bladders: 9 Bladders External CD: Not PResent CGEA Version: CGEA Version 1.2 (also set C1MCA) Heated Windshield HMI: Not present Rear Climate Type (Only applicatible when rear climate configured): Rear manual w/o air flow mode Travel Link: Off Nav Repeater Conformance: Off Multi-Contoured seats:Available First letter of country code-ascii: Second letter of country code-ascii: U Splash Screen: Splash Screen 1 Vehicle style: reserved SDLC: Vehicle Settings - B-car only: On RVC Split view: Available 360 Camera view: Not available B299 Strategy: Not available DAFVC Split view: Not available Hill Start Assist - B-car only: Off ESP setting - B-car only: Off ESP hard button timer - B-car only: FoE Message Center HMI - B-Car Only: Off List Browser: Navigation and Media Electronic Horizon: Electronic Horizon Off V363 Strategy: Not available Outside air temperature HMI: Off Flank Guard HMI: On Charge Port Lock: Not present Park Brake Type: Mechanical Park Brake (use signal PrkBrkActv_B_Actl) Electronic Stability Control (ST vehicles): Not available RainSensor - B-Car only: Not available Hazard Spot warning: NA MyKey settings - B-car only: Available Trailer Backup assist: Not available Rear Defrost: On Deep Sleep: Deep Sleep off REVEL sound System: Not present PDC Architecture: CGEA 1.3 Architecture TCU: Present Multi Camera Strategy: Hard Button Camera Toggle Trailer Reverse Guidance: Disabled CHMSL Camera: Disabled Aux Camera: Disabled Autostore: Enabled Electronic Horizon type: MPP + Stubs ICP(EFP) Type: EFP ICP(EFP) Branding: non-Branded ICP(EFP) Network: Can ECALL: Enabled Online traffic for SA and China: Disabled Brazil Frequency: non-brazil or brazil frequencyis not supported by radio AM longwave/DAB L-Band: Enabled (or non-european radio) Enhanced memory: Disabled CGEA1.3+ illumination strategy: non-cgea1.3 Illumination change step/gradual: step change CD alert popup:disabled Cross-trafic[sic] Alert: disabled Number of personalizions: disabled South american freqency: non-south america or south america frequency not suported by radio BT pairing timeout: 0 GPS mount type: roof mount Vehicle: non HEV, BEV, PHEV Visual design Variants: Ford Classic Drive Type: FWD Key Combination: Volume down + F1 Audio Player: No media bluetooth Audio Profile index: profile 1 Climate Domain (will also diable climate vr): Fan repeater: ON Temperature Repeater: ON Climate: E8 BT Vehicle Nameplate ID: SYNC ADAS Feature Level: Electronic Horizon Off Parking Assistance: NO PDC/PSM/SAPP (non or configuration C5) Front track: 0.0100000 In Rear Track: 0.260000 In Wheel Base: 0.000000 In Internal Gyro: Not present Gyro on Bus: Not present Vehicle Weight: 100.000000 KG ECO Route Curve: 3.000000 Powertrain efficiency: 0.000000 % Regenerative Braking efficiency Highway: 0.392157% Regenerative Braking efficiency City: Max value violated Install angle of APIM for accelerometer X: 36.240002 degrees Install angle of APIM for accelerometer y: 62.580002 degrees Wheel ticks to revolution front: 40.000000 Wheel ticks to revolution rear: 40.000000 Tire circumference: 121.000000 cm Distance from IP to rear axle: 103.000000cm And here is the corresponding as-built: As I say, I'll try and post up a link to a Google sheets doc so we can all contribute. PM for the password when its up! And of course, If anyone can decipher any of the acronyms that'd be a huge help! EDIT: GOOGLE SHEET LINK!! 3 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted June 24, 2018 Share Posted June 24, 2018 I have changed the start up screen on my Sync3 and also have different colours for each tab. I tried a few other things as far as I remember but they didn’t work. This is a great idea! 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 25, 2018 Share Posted June 25, 2018 Codes for adding climate control to screen?Sent from my SM-G965F (S9+) Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 25, 2018 Author Share Posted June 25, 2018 12 hours ago, Stoney871 said: Codes for adding climate control to screen? Sent from my SM-G965F (S9+) Change 7D0-04-01 XXXX XXX* XXXX. The * should be a 1, change it to a 0. EDIT: That was according to the f150 doc. Just checking my apim settings, this is a 1 for me and it is enabled... But at the moment, several of us are having problems with the on screen controls changing the opposite side temp. I think thats something to do with this line in the APIM config: Vehicle Driver Location: Right Hand Drive (When user selects Driver HMI button, send passenger occupancy mode can signal) If we can change the byte for this setting, I'm thinking it should change it over... The other problem is that I am basing the settings on the findings of guys in the F150 forum. Cross referencing those with my APIM As Built doesn't seem to tally with some of the values. Ultimately, I need as many APIM configs and as built sets as possible to compare! 1 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 25, 2018 Author Share Posted June 25, 2018 Ok, going through my Apim config, matching up the bytes to the f150 doc, (linked to by luke in the preface sync 2 upgrade sticky). a lot of it matches up, but there are several values which don't and several bytes unaccounted for. This is going to mean a lot of trial and error testing, and hopefully, nothing irrevocably bad happening to my apim! Out to the car! Quote Link to comment Share on other sites More sharing options...
mastachaz Posted June 25, 2018 Share Posted June 25, 2018 14 hours ago, Stoney871 said: Codes for adding climate control to screen? Sent from my SM-G965F (S9+) they do but I dont know wich one , then i can remove it. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 25, 2018 Author Share Posted June 25, 2018 8 minutes ago, mastachaz said: they do but I dont know wich one , then i can remove it. 2 hours ago, Phil21185 said: Change 7D0-04-01 XXXX XXX* XXXX. The * should be a 1, change it to a 0. EDIT: That was according to the f150 doc. Just checking my apim settings, this is a 1 for me and it is enabled... Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 25, 2018 Author Share Posted June 25, 2018 I'm sat in the car and have just been doing a bit of fiddling and I've realised that some of my settings in the APIM config screen have changed and it appears to be the ones that were duplicates. I've edited the first post to show what it is now anyway... Quote Link to comment Share on other sites More sharing options...
mastachaz Posted June 25, 2018 Share Posted June 25, 2018 2 minutes ago, Phil21185 said: I'm sat in the car and have just been doing a bit of fiddling and I've realised that some of my settings in the APIM config screen have changed and it appears to be the ones that were duplicates. I've edited the first post to show what it is now anyway... let me know how to disable it. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 25, 2018 Author Share Posted June 25, 2018 1 hour ago, mastachaz said: let me know how to disable it. Change 7D0-04-01 XXXX XXX* XXXX. I'm still figuring out the values, but likely is a 1. Change to 0. @Stoney871, I messed up the first post by editing it with the updated APIM config. Is there a way to recover it as it was before? EDIT: Never mind, I pulled it from Google's cache =] 1 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 26, 2018 Author Share Posted June 26, 2018 Right, I've made a start on decoding the APIM. There is actually a lot of difference between (at least my) APIM and the settings defined on the f150 document. Kudos should be initially to those guys for their efforts, but I am attempting to build on what they've done. There is a link in the first post now to a read only Google Sheet. I've only done 2 of the code blocks so far, but I hope to add more as we go! Quote Link to comment Share on other sites More sharing options...
Metalzone Posted June 26, 2018 Share Posted June 26, 2018 Have you tried this?https://forscan.org/forum/viewtopic.php?f=16&t=4385&start=10 1 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 26, 2018 Author Share Posted June 26, 2018 I hadn't but to be honest it'd be great to have all the info in one place and as o say, some of the settings done by those guys on the F150 forums don't match with mine. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 26, 2018 Author Share Posted June 26, 2018 The first code block has now been completely decoded, though some of the descriptions still need deciphering lol! Check the link in the first post. Quote Link to comment Share on other sites More sharing options...
zav2384 Posted January 20, 2020 Share Posted January 20, 2020 Quote The first code block has now been completely decoded, though some of the descriptions still need deciphering lol! Check the link in the first post. were you able to define other values in the configuration of the APIM module? Do you know which parameter is responsible for setting "Internal Gyro" and "GPS mount type"? Quote Link to comment Share on other sites More sharing options...
zav2384 Posted January 20, 2020 Share Posted January 20, 2020 On 6/27/2018 at 1:14 AM, Phil21185 said: The first code block has now been completely decoded, though some of the descriptions still need deciphering lol! Check the link in the first post. incorrectly quoted the first post, sorry Quote Link to comment Share on other sites More sharing options...
