Cruise control retrofit
Hi how would you check if you can retrofit cruise control to your car.
I know what I need to look for I just don’t know where the wire loom is located
a step by step explanation would help
I'm in the same boat with you buddy trying to get it for my wee 1.2 11 plate fiesta
you can check by taking the 3 back torx screws out and then they should pull apart and the wire loom should be under side of the steering wheel
You need the wires as shown below.
And where can i locate that?
It’s described in the post above the photo
