Start/Stop Battery
Can anyone recommend a replacement battery for my 2012 1.6 Tdci Fiesta which has Stop/Start ?? Does it have to be an EFB battery ?
yes , efb.
bosch s5 efb battery is a good one to have , or varta is another good make.
You can replace efb with agm. But you can't replace agm with efb. I've replaced the original 60ah efb with a 75 ah agm.
Cheers. Is it a straight swop or does the battery have to be matched to the car ??
after putting new battery on the bms (battery monitoring system) needs resetting.
there is a sequence with ign on with  fog light switch and hazzards but i can never remember it. will have a look if i can find it.
Ign on for 10 secs
press rear foglamp switch 5 times
press hazard switch 3 times
wait up to 10 seconds while watching battery light
battery light flashes confirming completed
ign off
Many thanks. Thats a great help......and saves £30 having it fitted !
