Air con query, help needed!
Just got round to looking why mine has cold air on left vents and warmish right vents. Check air con refrigerant. Had 248grams in. Should be 540 grams. Recovered, vac for 20 mins and put 540grams in. Now icy cold air out all vents. Result.
  • 2 years later...
Hi, I also have the same problem but I have had the ac regassed and pressurised. No leaks were present. The passenger side is ice cold but the driver's side is about 4 degrees warmer when set to Lo. Compressor and everything else is operating correctly. The ac guy said it might be the blend door actuator but it is fine when set to hot in winter. Also, I found two blend door actuators when I looked on the driver's side. Any ideas would be welcome, thanks. Focus ST 2016
