Soot in exhaust
michaelburrows
 Share
All diesels no matter what will get lots and lots of soot lol hence dirty diesels lol
Dpf doesn't catch all of the soot (it's for gases mostly which it burns off)
* in brackets is wrong
Link to comment
26 minutes ago, Paramanic said:
Dpf doesn't catch soot it's for gases mostly which it burns off
That's completely wrong, the Diesel Particulate Filter is there to catch particulate matter such as soot. This is then burned off during a regeneration leaving behind some ash.
  • Like 2
Link to comment
Stick to petrols @Paramanic! :tongue:  As Mike says, the DPF is literally a filter for particulates (soot).  It has no effect on gasses at all.  They also have a cat before the DPF to reduce certain gasses like CO which your dirty petrols produce far more of lol.  And an EGR valve to reduce NOx gasses, which again, your dirty petrols produce more of now they're direct injection lol.
There shouldn't be any soot on a DPF tail pipe in an ideal world.  Diesels are no longer visibly dirty.  You certainly shouldn't have a thick black coating around the tip like you would on a pre-DPF diesel.  A light coating isn't unacceptable though.
I've currently got a 1.6TDCi with a DPF and a 2.0TDI with a DPF...tail pipes are clean on both. :smile:
  • Like 2
Link to comment
Got mixed up with adblue my bad [emoji23][emoji23][emoji23]
Burns off to make water vapour basically [emoji23] but all diesels still get soot in exhaust visible soot no so when you rev non should appear but your clean rear of the car will get soot and soot will be on the exhaust
  • Like 1
  • Haha 1
Link to comment
Going off mates VW GTD btw which isn't modded my cars exhaust has got soot on it but I've never cleaned it yet to know how much lol
Link to comment
VAG fit straight tips to DPF models as there shouldn't be any soot from them.  They always fitted downturned tips to non-DPF models.
My tips are still perfectly clean...cleaner than some of the petrols I've had tbf lol, just wish they were shiny and rolled from the factory as well.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
