SirMalc Posted August 12, 2018 Share Posted August 12, 2018 Hi all, I own a 2004 Ford Focus Mk1 that has a low idle speed issue. When the engine is fully up to temperature and I let off the throttle, the revs will fall back down too low, causing the car to judder before the car sorts itself out and finds the correct 750RPM idle. This issue is much more pronounced under a heavy electrical load (air-con/headlights etc.) with the air-con managing to sometimes stall the car completely. I have recently changed: Air Filter, Oil/filter, Idle speed control valve, alternator, cleaned the throttle body plate, spark plugs, fuel filter. None of which has fixed the issue. Another issue of note is that the engine can be heard 'pinking' when accelerating under load (high gear, low revs) uphill. Not sure if this could be related to my idle issue, such as the fuel being too lean or the car can't figure out the correct air/fuel mix. After a lot of googling I came across this thread from 2009: https://forums.overclockers.co.uk/threads/ford-focus-idle-problem-plus-others.17960952/ . I'm not taking it as gospel, but I did wonder if my car also needed this ECU/PCM update, especially as my car is not throwing up any error codes and is from the same year. I took it to Think Ford in Guildford near me who said they cannot find any vacuum leaks on the engine at all, so I've asked them to see if they can update the ECU but I'm phoning on Monday to see if they managed to update it. One of the mechanics there beforehand did express concern that being a 14 year old Ford, they may not be able to update it due to it being incompatible with the software or that updates are no longer available. But I presume being an official manufacture garage they should still be able to access software updates for old vehicles of theirs surely? I can't imagine these cars rolled off the production line like this, so there must be something that needs fixing. Has anyone here experienced similar issues or have any suggestions as to what could be causing this issue? Many thanks, Malcolm. Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted August 12, 2018 Share Posted August 12, 2018 What is the idle like when the engine is up to temperature and you disconnect the the plug to the idle control valve? ie Base idle. Quote Link to comment Share on other sites More sharing options...
SirMalc Posted August 12, 2018 Author Share Posted August 12, 2018 30 minutes ago, Dave Kelly said: What is the idle like when the engine is up to temperature and you disconnect the the plug to the idle control valve? ie Base idle. That’s something I’ve read about and I will try when I get the car back from the garage. I presume the car will compensate by opening the throttle body plate? i cleaned the original ICV with carb cleaner which didn’t help, then proceeded to replace it with an aftermarket ICV. Neither fixed the issue. Potentially the aftermarket one could also be duff, but I doubt it. Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted August 12, 2018 Share Posted August 12, 2018 If the valve is operating correctly, the ECU will then hold the RPM at tick-over 100rpm to 150rpm above base once reconnected. Quote Link to comment Share on other sites More sharing options...
SirMalc Posted August 12, 2018 Author Share Posted August 12, 2018 7 minutes ago, Dave Kelly said: If the valve is operating correctly, the ECU will then hold the RPM at tick-over 100rpm to 150rpm above base once reconnected. What happens to the RPM when the valve is disconnected? Or do you mean it will hold +100rpm until the valve is reconnected? Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted August 12, 2018 Share Posted August 12, 2018 When you disconnect the electrical plug connector, the idle should be at 750rpm. (Base Idle) Once you connect the electrical plug, the ECU should take over and raIse the RPM accordingly. (to 850-900 rpm) Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted August 12, 2018 Share Posted August 12, 2018 With regards to your other issue, "Pinking" otherwise known as pre ignition, this could be due to a number of things. When did you last change your plugs? Also, what sort of mileage has the car done? Quote Link to comment Share on other sites More sharing options...
SirMalc Posted August 12, 2018 Author Share Posted August 12, 2018 1 hour ago, Dave Kelly said: With regards to your other issue, "Pinking" otherwise known as pre ignition, this could be due to a number of things. When did you last change your plugs? Also, what sort of mileage has the car done? I changed the spark plugs 3 weeks ago with new Bosch ones. Coil pack hasn’t been changed but I think there’d be bigger issues if that was failing. Car mileage is about 80k. I did did wonder if one of the fuel injectors may be dodgy. I could try using some additive in with the next fuel load, or maybe try a higher quality fuel as I normally get standard supermarket petrol. Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted August 15, 2018 Share Posted August 15, 2018 I believe that you can do a resistance check on the injectors so as to eliminate them, not sure of the correct value though. If you can test all 4 and they are the same, then at least we can eliminate them. Do you know if the timing is controlled by the ECU in conjunction with a crank angle sensor? Quote Link to comment Share on other sites More sharing options...
SirMalc Posted September 30, 2018 Author Share Posted September 30, 2018 On 8/12/2018 at 6:49 PM, Dave Kelly said: When you disconnect the electrical plug connector, the idle should be at 750rpm. (Base Idle) Once you connect the electrical plug, the ECU should take over and raIse the RPM accordingly. (to 850-900 rpm) Sorry to revive my old thread but I still have this issue. Today I replaced the PCV valve which has made no difference. Afterwards I drove the car up to operating temperature, came home and disconnected the ICV whilst the car was running and the idle immediately dropped to about 333RPM and began to labour badly but did not stall. As soon as I reconnected the ICV the RPM went back up to around 666RPM. Could this potentially mean something is off with my car's base idle setting? Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted September 30, 2018 Share Posted September 30, 2018 I would say yes, I would have thought your base idle should be around the 650rpm range with the ICV disconnected. Once that is adjusted, i would imagine that your natural idle once the ICV is reconnected should be around the 850rpm mark. Quote Link to comment Share on other sites More sharing options...
Abbadon Posted October 1, 2018 Share Posted October 1, 2018 Being electronically controlled, would this point to a sensor issue affecting base idle - I wouldn't expect there to be adjustable timing as such on this engine? So crank or cam sensor (making the assumption it has both?) Quote Link to comment Share on other sites More sharing options...
Dave Kelly Posted October 23, 2018 Share Posted October 23, 2018 I am not a 100% certain, but I would imagine the base idle to be adjustable. That is a low rpm disconnected at rpm333 but is encouraging to see it lift once connected. Any photos of ICV? Quote Link to comment Share on other sites More sharing options...
