bp70 Posted August 17, 2018 Share Posted August 17, 2018 Hello again, Having read the owner's manual, thanks to Frembrit, I'm enjoying driving my aged Mondeo. Very comfortable and smooth drive, long may it be so. In the spirit of continued learning, I'm now looking for the Sony CD6 manual, hopefully including resolution of errors. Unit was apparently working when battery was disconnected for repair work. Now having recovered the lost code, not available when I picked the car up, when the unit is turned on, entry of the code does nothing. Presumably, the code is wrong, I should press something after entering the code but don't know what, I need to resolve the cd error or the unit is kaput. Car manual says It gives 10 goes at entering the code and, if incorrect, locks up tight. That doesn't seem to be the case here. Can re-enter the code as many times as I like but no go. Would be grateful for directions to the unit manual and advice. Many thanks. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted August 17, 2018 Share Posted August 17, 2018 where did you get the code from? A ford dealer will charge you i think £15 to get the code. As to the cd error its very common with this unit and its very expensive to get sorted it a mechanical fault with in the unit Quote Link to comment Share on other sites More sharing options...
al2052 Posted August 17, 2018 Share Posted August 17, 2018 You have message Quote Link to comment Share on other sites More sharing options...
bp70 Posted August 21, 2018 Author Share Posted August 21, 2018 Hi, apologies all. Seems I've only thought I'd replied but not actually submitted my responses to messages received. I found tucked in sun visor out of sight but for corner. Hope to receive another unit via eBay shortly🤔 Thanks for reply. Quote Link to comment Share on other sites More sharing options...
1.Morningstar Posted August 21, 2018 Share Posted August 21, 2018 One for future use. I needed a code for my car & used Autoradiocodes on e bay & cost me just 99p. The seller replied within a few minutes with the correct code & instructions on how to input https://www.ebay.co.uk/itm/FORD-RADIO-CODE-STEREO-CODES-PIN-CAR-UNLOCK-FAST-SERVICE-6000CD-6006CDC/202306471459?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 No problems here 1 Quote Link to comment Share on other sites More sharing options...
bp70 Posted August 21, 2018 Author Share Posted August 21, 2018 Thanks very much 1.Morningstar Quote Link to comment Share on other sites More sharing options...
al2052 Posted August 21, 2018 Share Posted August 21, 2018 Ford audio manual although issued for MK4 covers most models Ford Audio Systems .pdf 1 Quote Link to comment Share on other sites More sharing options...
bp70 Posted August 21, 2018 Author Share Posted August 21, 2018 Thanks very much al2052. Cheers. Quote Link to comment Share on other sites More sharing options...
