frund Posted August 27, 2018 Share Posted August 27, 2018 Sometimes they lock. I read a search on here and a chap changed his door loom and it was still the same. The last time it would not lock I wiggled the drivers rubber boot and it locked. Earlier i closed the door a couple of times and this worked. 10 years this door would have had a lot of use. The rubber boot looks like new could it be a short somewhere. Any ideas ta Quote Link to comment Share on other sites More sharing options...
isetta Posted August 28, 2018 Share Posted August 28, 2018 more likely a broken wire than a short (like the plastic sleeve is still in one piece but the copper inside is breaking) Quote Link to comment Share on other sites More sharing options...
frund Posted August 31, 2018 Author Share Posted August 31, 2018 Yes may well be broken wire. I should have said it locks then unlocks immediately. Once I get it to lock it stays locked then it may be ok for a few times then the problem reoccurs. I have not had a chance to look at it yet but I would have to cut the rubber boot off by the look of things. Quote Link to comment Share on other sites More sharing options...
