Jonson Posted September 3, 2018 Share Posted September 3, 2018 Here's an odd one: for no apparent reason, as of this morning, the sound of my warning beeps/chimes for park sensor and door open have changed - it's gone sort of quieter, more high pitched and tinny. Hard to explain but it's very noticeable. Anyone else had this? Quote Link to comment Share on other sites More sharing options...
Mavroz Posted September 4, 2018 Share Posted September 4, 2018 Not had this /but heard something similar in the past although not on a car. I am guessing the beeps/chimes and sensor noises are from a separate speaker and this may have gone faulty. Quote Link to comment Share on other sites More sharing options...
Jonson Posted September 4, 2018 Author Share Posted September 4, 2018 Yep, seem to come from a speaker near the dials somewhere. And weirdly - now back to normal..... Quote Link to comment Share on other sites More sharing options...
Mavroz Posted September 6, 2018 Share Posted September 6, 2018 Silly as it seems, things like an insect on or in the speaker could cause distorted sound. Unusual but possible. Quote Link to comment Share on other sites More sharing options...
agauld96 Posted October 29, 2019 Share Posted October 29, 2019 On 9/3/2018 at 8:52 AM, Jonson said: Here's an odd one: for no apparent reason, as of this morning, the sound of my warning beeps/chimes for park sensor and door open have changed - it's gone sort of quieter, more high pitched and tinny. Hard to explain but it's very noticeable. Anyone else had this? Did this ever get sorted? My brand new Fiesta st is now doing this only picked it up yesterday.. Quote Link to comment Share on other sites More sharing options...
Eliterox Posted October 29, 2019 Share Posted October 29, 2019 Hello, I've had this issue before. It happens when the sound system crashes. Last time it happened my sync 2.5 system froze and i had to hard reset it. When it started back all the sounds were playing from a tiny speaker behind the dash gauges. Ford built that backup system in case the media player fails. It fixed itself back overnight since when i started the car next day all was working as intended. It hasn't happened again ever since. Quote Link to comment Share on other sites More sharing options...
Jonson Posted October 29, 2019 Author Share Posted October 29, 2019 I've had this happen a handful of times now in the last 18 months - always back to normal at next restart, but don't know the root cause. Quote Link to comment Share on other sites More sharing options...
djmeero Posted July 13, 2020 Share Posted July 13, 2020 Hey, I know it's been a while...but I'm experiencing the same problem....the chimes and parking sensors sounds output are all from IPC, I checked the setting in Forscan the output of chimes is set primary to Speakers...I don't think it's a fuse because there were 2 times when it worked...but I was on a bluetooth call and somehow it worked... after turning off and back on the car, the problem returned...I recently upgraded to Sync 3...but this problem was before too...do someone have a solution? The car is a 2016 Mondeo Hybrid. Thanks. Quote Link to comment Share on other sites More sharing options...
Bart8090 Posted October 5, 2020 Share Posted October 5, 2020 Just got brand new 70 plate transit custom and does exactly the same, sometimes it helps when I slam the door close but not every time. Very annoying . it looks like software as it most of the time fixes itself without any action. Quote Link to comment Share on other sites More sharing options...
tomshepp Posted October 5, 2020 Share Posted October 5, 2020 If slamming the door has an effect it is without a doubt that the problem is due to a loose connection. You can't slam software. Quote Quote Link to comment Share on other sites More sharing options...
Jim H Posted October 5, 2020 Share Posted October 5, 2020 This has happened to me on several occasions, (did it yesterday), still no idea what causes it. As above, sounds like an internal speaker instead of main Speakers. Quote Link to comment Share on other sites More sharing options...
Peste Posted February 23, 2021 Share Posted February 23, 2021 Same happens to me Ford Fiesta ST Line 2020. I Start the car and open the door and listen some weird warning noise, diferent than the usual. Quote Link to comment Share on other sites More sharing options...
Waggy Posted February 23, 2021 Share Posted February 23, 2021 There are literally dozens of posts on this topic. It happens when the battery monitoring system is reporting low charge in the battery, part of the power saving system. Either give the battery a good charge or reset the BMS to make it go away, for a while anyway. Peste 1 Quote Link to comment Share on other sites More sharing options...
The Latman Posted March 29, 2021 Share Posted March 29, 2021 On 2/23/2021 at 4:51 PM, Waggy said: There are literally dozens of posts on this topic. It happens when the battery monitoring system is reporting low charge in the battery, part of the power saving system. Either give the battery a good charge or reset the BMS to make it go away, for a while anyway. I have had this problem on and off with my Mk V Mondeo. Had it in the dealers for a service, coincidentally at the time, this was happening. They 'Couldnt see anything wrong' and told me 'This was normal behaviour' according to their technician. I countered that I hadn't ever seen this before in all 4 years of ownership since new, they just shrugged. They had dont a battery test, told me it was a "Good" battery with a "Good" level of charge. I had had the car out for a run, just to charge the battery in case that was the issue. I manually reset the BMS a few days later, went away, until yesterday. Its not been for a decent run recently, we are still locked down in Scotland and not allowed to leave the area. Undoubtedly this time the battery is low, but, wanted to ask a question: Why would resetting the BMS sort this issue, albeit temporarily, if the battery is low? Quote Link to comment Share on other sites More sharing options...
Waggy Posted March 29, 2021 Share Posted March 29, 2021 2 hours ago, The Latman said: Undoubtedly this time the battery is low, but, wanted to ask a question: Why would resetting the BMS sort this issue, albeit temporarily, if the battery is low? Excellent question. I've not seen any posts which explain how this "smart" system actually works. But I think most people accept there is some sort of problem whereby the BMS reports a low state of charge, starts to shut things down, but the battery itself is perfectly healthy. All we know for now is that the problem has reared its head since many people are using their cars less frequently and that resetting the BMS gives a temporary fix. The Latman 1 Quote Link to comment Share on other sites More sharing options...
The Latman Posted March 29, 2021 Share Posted March 29, 2021 1 hour ago, Waggy said: Excellent question. I've not seen any posts which explain how this "smart" system actually works. But I think most people accept there is some sort of problem whereby the BMS reports a low state of charge, starts to shut things down, but the battery itself is perfectly healthy. All we know for now is that the problem has reared its head since many people are using their cars less frequently and that resetting the BMS gives a temporary fix. Same here, all I keep reading is how "advanced" it is. Yet, when you replace a battery, it's good practice to reset it manually, rather than let it pick up the new battery itself, which is insane. When I handed mine into the dealer, they compared it with another mondeo on the showroom floor, it did the same thing (weird chimes/message on screen), i laughed and told them they had 2 cars with the same issue then. I was dismissed and told "No, that's perfectly normal". I now have video footage of it behaving, and video footage of it misbehaving, in case I ever decide to go back to the dealer about it again, today, its behaving again. Quote Link to comment Share on other sites More sharing options...
bestbiltong Posted May 22 Share Posted May 22 This has just happened to me now on my 2021 Ford Transit Custom. Turning vehicle off and on hasn’t worked. A couple of weeks ago, I broke suddenly and a loud piercing internal alarm sounded. It was so loud and piercing, you couldn’t sit in the cab. When starting the engine it stopped briefly then started again. It stopped after about 25mins. Ford didn’t know what it was and couldn’t help. I do have an issue with the media console crashing frequently. Quote Link to comment Share on other sites More sharing options...
