PedroFiesta Posted September 16, 2018 Share Posted September 16, 2018 Hello, I have recently bought a (new for me) 2009 Ford Fiesta Zetec from a private seller. It only has the aux port (no USB connection) and when I press the phone icon it comes up with 'MUTE' and a speaker symbol with a cross through it - same for aux. When I plug in my aux cable nothing happens my phone is unable to connect to the car and when I search for the car to sync on bluetooth no options come up. I was really looking forward to playing my music in this car and having the hands-free option to answer my phone from my steering wheel but I am at a loss. If you could help I would greatly appreciate it. Kind regards, D Quote Link to comment Share on other sites More sharing options...
pragmatix Posted September 16, 2018 Share Posted September 16, 2018 Sounds like you dont have bluetooth which is what you need for the phone i think you need a titainum to get this, however all is not lost the bluetooth module can be added, not sure about which version but others no doubt will be along with the right info Quote Link to comment Share on other sites More sharing options...
StWou7 Posted September 19, 2018 Share Posted September 19, 2018 Yes, it certainly sounds like no bluetooth (i had a 2009 Titanium with no bluetooth....i assume at that time it was an option that wasn't selected by the original owner) the phone button is simply muting what ever is playing on the stereo. If you have an iPhone i was simply using voice activated Siri to dial with the phone plugged into the AUX output (Calls went via the speakers) i had to shout a little louder so the person at the other end could hear but it worked for my short "Im on the way" kind of calls. Obviously you cant answer calls as you cant hold/touch your phone at all whilst driving so admittedly its quite a drawback. Quote Link to comment Share on other sites More sharing options...
alextheodoridis Posted May 10, 2019 Share Posted May 10, 2019 I have the same problem.did you finally find out where the problem was? Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted May 11, 2019 Share Posted May 11, 2019 14 hours ago, alextheodoridis said: I have the same problem.did you finally find out where the problem was? It's not a problem with the stereo as such, it's just you dont have bluetooth fitted. 1 Quote Link to comment Share on other sites More sharing options...
max111 Posted July 26, 2019 Share Posted July 26, 2019 i have the same problem but the blutooth and usb and line in, voice command button and interior light thingy are fitted and i have checked the fuses tried replacing the module aaaaaaaarrrrrrrhhhh still dont work ...... anybody any ideas??? 1 Quote Link to comment Share on other sites More sharing options...
DanniC Posted August 22, 2019 Share Posted August 22, 2019 I have the same problem however my car does have bluetooth as I have had this connected for the past 3 years, now it doesn't work! Help please! Quote Link to comment Share on other sites More sharing options...
Shaikdilshad Posted May 8, 2020 Share Posted May 8, 2020 Ford fiesta 2011 midel titanium When i was press aux or bluetooth it come to radio or mute What i can do ? 1 Quote Link to comment Share on other sites More sharing options...
FiestaPhillip Posted October 6, 2020 Share Posted October 6, 2020 Any ideas on how to solve this? I have a 2010 Fiesta Titanium which has bluetooth and it had all been working fine, however I’ve just had to replace the battery and now the phone/Bluetooth no longer work, the phone option just says Mute and I can’t select the bluetooth on my phone. Can anyone help with this, please? Quote Link to comment Share on other sites More sharing options...
tomshepp Posted October 6, 2020 Share Posted October 6, 2020 System reset then re pair. Quote Link to comment Share on other sites More sharing options...
Beckynnnnnnn Posted February 9, 2021 Share Posted February 9, 2021 On 10/6/2020 at 10:39 AM, FiestaPhillip said: Any ideas on how to solve this? I have a 2010 Fiesta Titanium which has bluetooth and it had all been working fine, however I’ve just had to replace the battery and now the phone/Bluetooth no longer work, the phone option just says Mute and I can’t select the bluetooth on my phone. Can anyone help with this, please? Hi the same thing happened to me, did you find a solution? Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted February 9, 2021 Share Posted February 9, 2021 8 hours ago, Beckynnnnnnn said: Hi the same thing happened to me, did you find a solution? Usually its just a case of a dead bluetooth module. Quote Link to comment Share on other sites More sharing options...
Stephen Taylor Posted August 3, 2021 Share Posted August 3, 2021 On 9/19/2018 at 4:17 PM, StWou7 said: Yes, it certainly sounds like no bluetooth (i had a 2009 Titanium with no bluetooth....i assume at that time it was an option that wasn't selected by the original owner) the phone button is simply muting what ever is playing on the stereo. If you have an iPhone i was simply using voice activated Siri to dial with the phone plugged into the AUX output (Calls went via the speakers) i had to shout a little louder so the person at the other end could hear but it worked for my short "Im on the way" kind of calls. Obviously you cant answer calls as you cant hold/touch your phone at all whilst driving so admittedly its quite a drawback. But I do have bluetooth in my car and it is switched on Quote Link to comment Share on other sites More sharing options...
unofix Posted August 3, 2021 Share Posted August 3, 2021 12 minutes ago, Stephen Taylor said: But I do have Bluetooth in my car and it is switched on Congratulations 👍 Quote Link to comment Share on other sites More sharing options...
Stephen Taylor Posted August 3, 2021 Share Posted August 3, 2021 1 minute ago, unofix said: Congratulations 👍not helpful I have the same problem, but my bluetooth is switched on in my car 1 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted August 3, 2021 Share Posted August 3, 2021 38 minutes ago, Stephen Taylor said: I have the same problem, but my Bluetooth is switched on in my car Like I said above, probably a dead/faulty module Quote Link to comment Share on other sites More sharing options...
benny_balau Posted November 6, 2022 Share Posted November 6, 2022 On 7/26/2019 at 11:30 PM, max111 said: i have the same problem but the blutooth and usb and line in, voice command button and interior light thingy are fitted and i have checked the fuses tried replacing the module aaaaaaaarrrrrrrhhhh still dont work ...... anybody any ideas??? Same for me!!! Escavar same did you fix it? And how please tell me😑😩 1 Quote Link to comment Share on other sites More sharing options...
benny_balau Posted November 6, 2022 Share Posted November 6, 2022 On 7/26/2019 at 11:30 PM, max111 said: i have the same problem but the blutooth and usb and line in, voice command button and interior light thingy are fitted and i have checked the fuses tried replacing the module aaaaaaaarrrrrrrhhhh still dont work ...... anybody any ideas??? Same here!!! Eaxactly the same, was you able to fix it? And how please help me if you know!🙏😩 Quote Link to comment Share on other sites More sharing options...
benny_balau Posted November 6, 2022 Share Posted November 6, 2022 Just now, benny_balau said: Same here!!! Eaxactly the same, was you able to fix it? And how please help me if you know!🙏😩 Quote Link to comment Share on other sites More sharing options...
ARS Posted November 10, 2022 Share Posted November 10, 2022 On 11/6/2022 at 9:29 PM, benny_balau said: Hi, i had the same problem and you can upgrade your whole stereo or get one Fm transmitter and that solve the problem if didn't massage me i can it sorted for u 1 Quote Link to comment Share on other sites More sharing options...
Alina Posted September 11, 2023 Share Posted September 11, 2023 On 06.11.2022 at 23:29, benny_balau said: Quote Link to comment Share on other sites More sharing options...
Alina Posted September 11, 2023 Share Posted September 11, 2023 did you solve the problem? if so, how? I have the same problem Quote Link to comment Share on other sites More sharing options...
unofix Posted September 12, 2023 Share Posted September 12, 2023 On 5/11/2019 at 1:03 PM, Luke4efc said: It's not a problem with the stereo as such, it's just you don't have Bluetooth fitted. Quote Link to comment Share on other sites More sharing options...
