Dreaded mk3 steering assist issue
tank121
 Share
So last Monday I got my 2012 Focus 1.6 titanium back from the MOT the only issue, being one tyre needed replacing.
I'm then got a warning about tyre pressure and so checked them but they all seemed OK and later on the warning went.
The following day ’steering assist malfunction service  required’ came on, and Imjust managed to drive home. Following a restart the message cleared. Yesterday it returned again at almost the same point in my journey home but this time will not clear with a restart.
There's no way, I could drive into work, my local Ford dealer can't see it until Friday.
A few weeks ago Halfords replaced the battery  to one of own brands. If I put the car into test mode the output voltage is showing around 14.3.
Is this a case of the known issue and the steering rack/sensor will need replacing?
I've tried disconnecting one side of the battery to see if it would clear it but no.
Anything else to try?
My mileage is 65000
Link to comment
My 2011 focus still gets the error sometimes on start-up in the morning but never while driving.
The pcm update seemed to extend the timer for the rack to kick in before showing the error as it can still feel stiff some morning's without the error appearing.
Since the pcm update about 6 months ago I have only had to stop the engine and restart it twice.
I did ring bba reman previously to check the price and it was a few hundred at the time. I also priced up second hand steering racks that were similar price but I can live with mine now as it has never happened while driving.
Just out of interest does yours have stop/start or just push button start like mine? It may affect the power to the steering rack.
Link to comment
By the way, if you have only had 1 tyre replaced and checked the pressures then hold down the right hand ok when on the screen to reset the sensors. I have had that happen when replacing tyres.
Link to comment
Does your car have the self  / auto park  feature?  If not I have a known working rack in my garage from a Titanium model that I tried to fit to my Titanium X  (which has the self park feature but is not compatible with my model !  ) Give me a shout if you are interested.
Link to comment
So I had the rack replaced and I was offered 2 different racks by the Ford garage, an original Ford one or a cheaper 3rd party one which they said they use a lot. I opted for the cheaper one, I've had the car back a week and noticed a creaking noise at the front of the car moving  from stationery. Is this to be expected from the new rack? The only other thing I've had done is 3 tyres replaced on Sunday by tyres on the drive and to be honest Monday was the first time I had no music on and really noticed the noise.
Link to comment
Well car went back to the dealer at the weekend and the rack was checked etc still making a creaking noise though, especially when going slow and reversing and wheel turning a full circle.
Total bill from Ford £786
  • Sad 1
Link to comment
  • 3 months later...
My power steering warning light has come on again and power steering has failed. Has anyone ever experienced this after after the rack replaced?? 😞
Link to comment
Fault codes from reader come someone help with the the power steering ones. Is it the rack again.
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===SASM DTC None===
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC U0151:00-68===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
 - Previously Set DTC - Not Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
 - Test not complete
Module: Antilock braking system
 Freeze Frame :
-GLOBTIM: 248428133 sec - Global real time
-TOTDIST: 110561.0 km - Total Distance
-MAINECUV: 14.50 Volt - Main ECU voltage supply
-OUTTMP: 23 °C - External Temperature From Sensor
===END ABS DTC U0151:00-68===
===ABS DTC U0126:00-2B===
Code: U0126 - Lost Communication With Steering Angle Sensor Module
Status:
 - DTC Present at Time of Request
 Freeze Frame :
-GLOBTIM: 249969081 sec - Global real time
-TOTDIST: 111570.0 km - Total Distance
-MAINECUV: 12.25 Volt - Main ECU voltage supply
===END ABS DTC U0126:00-2B===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===PSCM DTC U3000:49-48===
Code: U3000 - Control Module
Additional Fault Symptom:
 - Internal Electronic Failure
Status:
 - Test not complete
Module: Power Steering Control Module
 Freeze Frame :
-PWR_MODE_KEY: Key Out  - Power Mode Key State
-PWR_MODE_QF: Power Mode Undefined  - Power Mode Quality Factor
-SSHFT_TQ_S2: 0.2 Nm - Steering Shaft Torque Sensor #2
-MOD_SUP_V: 11.40 Volt - Module Supply Voltage
-PSCM_INT_TEMP: 22 °C - PSCM Internal Temperature
-VSS: 0.0 km/h - Vehicle Speed
-DLA_SED_FD0B_PID: 64   - DL_SED_FD0B_PID
-DLA_NUM_FD0C_PID: -0.02 Amper - DL_NUM_FD0C_PID
-DLA_NUM_FD0D_PID: 0.00 Amper - DL_NUM_FD0D_PID
-DLA_NUM_FD0E_PID_1: 0.0 Nm - DL_NUM_FD0E_PID_1
-DLA_NUM_FD0F_PID_1: 0 rev/min - DL_NUM_FD0F_PID_1
===END PSCM DTC U3000:49-48===
===PSCM DTC U3000:53-C8===
 - Deactivated
Status:
 - Malfunction Indicator Lamp is On for this DTC
 - Test not complete
 Freeze Frame :
-GLOBTIM: 249949663 sec - Global real time
-TOTDIST: 111519.0 km - Total Distance
-MAINECUV: 15.00 Volt - Main ECU voltage supply
-PWR_MODE_KEY: Running  - Power Mode Key State
-PWR_MODE_QF: Power Mode OK  - Power Mode Quality Factor
-SSHFT_TQ_S2: 0.1 Nm - Steering Shaft Torque Sensor #2
-MOD_SUP_V: 13.70 Volt - Module Supply Voltage
-DLA_SED_FD0B_PID: 105   - DL_SED_FD0B_PID
===END PSCM DTC U3000:53-C8===
===BCMii DTC None===
Module: Body Control Module
===END BCMii DTC None===
===FCDIM DTC U0155:00-04===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status:
 - DTC Maturing - Intermittent at Time of Request
Module: Front Control/Display Interface Module
===END FCDIM DTC U0155:00-04===
===SRM DTC None===
Module: Speech Recognition Module
===END SRM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC B12DD:54-2F===
Code: B12DD - Rear Window Motion/Position Sensor
 - Missing Calibration
Status:
Module: Drivers Door Module
 Freeze Frame :
-GLOBTIM: 248233647 sec - Global real time
-TOTDIST: 110388.0 km - Total Distance
-INCARTMP: 23 °C - In car temperature
-DLA_SED_DD07_BY_1_PID: error  - DL_SED_DD07_BY_1_PID
===END DDM DTC B12DD:54-2F===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===RFA DTC None===
Module: Remote Function Actuator
===END RFA DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
Link to comment
  • 2 years later...
  • 3 weeks later...
I have a 2012 Ford Focus SEL. For about a year I have had this steering assist fault happen but have been able to shut the car off and re start. Last week never corrected itself. Could anybody that has had this problem tell me what the problem is and how much it costs to fix. Please?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
