TDR|XTC Posted September 24, 2018 Share Posted September 24, 2018 Prior to an upgrade in power to the car I installed a pair of EBC Ultimax Brakes and EBC YellowStuff pads. Recently they started to have some weird symptoms. 1. When i brake from let's say 60mph there is like a hard woosh sound (sounds rigid and it's coming from the right side) 2. I once had to brake hard because a knucklehead did not gave me priority and on the right side it felt like it was slipping. Prior to this i did the following: 1. Changed the brake fluid pipe coming from the ABS modulator to the right side brakes. 2. Changed the brake fluid before putting the new discs on. 3. Changed the slider pins and added new lubricant to them. Something is not working as it should. Any thoughts ? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 24, 2018 Share Posted September 24, 2018 Pull the pads out and check them. I've seen yellow stuff friction material completely detach from the back plate before. But on this case it's likely the pads are glazed and just need roughing up a bit. Quote Link to comment Share on other sites More sharing options...
TDR|XTC Posted September 24, 2018 Author Share Posted September 24, 2018 Hello TomsFocus! Thank you for the reply. The pads are 2k miles, will check if the friction material detached, tomorrow. One more thing...just after i posted this message, i did a diagnostics check on the car and it came up with U0415:68-48 - Invalid data received from ABS Control Module. Weird... Quote Link to comment Share on other sites More sharing options...
isetta Posted September 24, 2018 Share Posted September 24, 2018 isn't there something special about bleeding brakes with ABS where you have to plug something in the diagnostic OBD port and tell it to open the valves in the ABS pump thing? I have never bled brakes on ABS cars but I thought I had read something about this on the fiesta or focus forum. I don't think I imagined it. Quote Link to comment Share on other sites More sharing options...
TDR|XTC Posted October 3, 2018 Author Share Posted October 3, 2018 Sorry for the late update. The pads are ok, discs look very good! On the ABS side of things I do get a U0415:68-48 (or :68-A0) saying that "Invalid data received from ABS Control Module" and in ForScan when streaming live data there is a ABSTCVVS (ABS Traction Control Valves - Valve Supply) that goes from ON to OFF then back to ON .....and it keeps doing this. Could the ABS CM be faulty ? Quote Link to comment Share on other sites More sharing options...
