k0r55 Posted February 18, 2010 Share Posted February 18, 2010 hey guys, i need some help as to where the best location to hook the ground wire cable to is, because i've only managed to find a small screw where the ground is weak and my sub keeps cuttin out every other day. so if anybody has a sub or amp hooked up can you please help me =] fanx guys Quote Link to comment Share on other sites More sharing options...
r3ign Posted February 19, 2010 Share Posted February 19, 2010 hey guys, i need some help as to where the best location to hook the ground wire cable to is, because i've only managed to find a small screw where the ground is weak and my sub keeps cuttin out every other day. so if anybody has a sub or amp hooked up can you please help me =] fanx guys in my old mk6 I started it under the boot ledge ( its hard to explain, but when you open your boot there's a ledge at the bottom about knee height. well the inside of that is complete metal and really good for earthing. just put a bolt through it and you're done) hope its clear enough Quote Link to comment Share on other sites More sharing options...
k0r55 Posted February 20, 2010 Author Share Posted February 20, 2010 in my old mk6 I started it under the boot ledge ( its hard to explain, but when you open your boot there's a ledge at the bottom about knee height. well the inside of that is complete metal and really good for earthing. just put a bolt through it and you're done) hope its clear enough Kool, thanks alot man, i have a rough idea at what your talking about, i'll do it probs 2moz or sunday. i'll let you know if it worked or not. much appreciated man thanks Quote Link to comment Share on other sites More sharing options...
Strutter Posted February 20, 2010 Share Posted February 20, 2010 ummm.....well if it hasn't worked right we wont know about that either. Quote Link to comment Share on other sites More sharing options...
wellzy Posted February 20, 2010 Share Posted February 20, 2010 bit more of a simple way of puttin. open the boot and look at the back of the rear lights (strip some interior out)and there's an earth a few inch's under them. Quote Link to comment Share on other sites More sharing options...
