Fiestareece Posted November 11, 2018 Share Posted November 11, 2018 Hi all have come seen similar issues for some people on here but can’t find any real solutions to what the problem was. so for the past few days my 2013 fiesta 1.0 ecoboost has been flashing up on start and when driving with the oil light and the message ‘low oil pressure stop slowly’ along with a rattle on the engine. It only has 27k on the clock. Checked oil and it was fine, to be safe i drained oil and changed the filter and added new oil. Light still on and warning message still coming on. So does anyone know the solution to this? I have also bought a oil pressure switch to change and rule that out but cannot find where it is on the engine to swap it if anyone can also help with its location? thank you in advance Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 I have a similar issue with a 1.25 where when engine is cold there is an awful rattleAssuming oil level is topped up correctly-could the oil sensor be at fault here- perhaps causing issues with the ECU hence causing the rattle Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 And I believe it is just above the oil cooler from what I can see ( below intake manifold) Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 Is this accessible from above or below ? Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 Is this accessible from above or below ? Below I believe buddy- but knowing ford probably at some obscure angle inaccessible from normal tools [emoji23]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 I was looking underneath earlier when changing the filter, the only thing i could see near that looked nothing like the oil pressure switch that i have got Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 Attached a photo of the one i picked up from euro, which should be the right one i assume. Definitely struggled to even see it when i got near the filter earlier Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 Picture of scrap engine on eBay- believe this is the pressure switch just next to the oil filterIf it looks nothing like the one on the engine- perhaps the wrong part? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 Possibly. Everywhere ive looked seems to give the same part that i picked up from euro. Even went into ford to compare. Will have another check in the morning when its lighter. Hoping it will sort it. Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 Yeah let me know buddy [emoji106]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 Thank you. Much appreciated Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 Think this is a better picture - seems to be just above the oil filter- which looks a lot more like the part you specified. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 11, 2018 Share Posted November 11, 2018 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
iantt Posted November 11, 2018 Share Posted November 11, 2018 It's probably the oil strainer in the sump blocked up, pressure switch won't make any difference if you have rattle as well. May need the sump removing and clear out the strainer. I've not done one but there have been a couple of members on here who have had too and clean strainer. 1 Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 Oh really, is the sump easy enough to remove? Anything tricky involved? And once removed is it just the case of goving it a good clean and removing any muck from the sump Quote Link to comment Share on other sites More sharing options...
isetta Posted November 11, 2018 Share Posted November 11, 2018 I'm sure I saw a thread on here maybe a year ago on an ecoboost where the strainer was blocked with small particles of something (it had the photos). I have tried finding it but can not. I never seem to have much luck with the search word function on this website. It might have been on focus forum as same engine. I assume the rattling is metal on metal of parts which are suffering from lack of oil pressure ie. all the time you hear the rattle, it is causing adverse wear of those components. Quote Link to comment Share on other sites More sharing options...
iantt Posted November 11, 2018 Share Posted November 11, 2018 How long have you had the car and what sort of journeys do you do? Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 11, 2018 Author Share Posted November 11, 2018 1 hour ago, iantt said: How long have you had the car and what sort of journeys do you do? Since new and only drive around town really. Got any ideas? Think its worth getting the sump off and checking the mesh filter everyone mentions? If i remove the sump do i have to remove the oil punp to clean the mesh out or can it be done whilst still in? Quote Link to comment Share on other sites More sharing options...
Jeipii Posted November 11, 2018 Share Posted November 11, 2018 Check this out: https://www.fordownersclub.com/forums/topic/98500-ecoboost-low-oil-pressure/ Quote Link to comment Share on other sites More sharing options...
Fiestareece Posted November 17, 2018 Author Share Posted November 17, 2018 Hi all finally got round to fixing the problem. The culprit being the oil pump. Just like siggy_7 had the same problem. Took the pump out and it was caked in so much thick muck in the filter mesh. No wonder no oil was getting pumped to the top of the engine, which was obviously causing the rattle being so dry. You can actually unbolt the front plate on the pump to get right in to the mesh to clean. Gave it a good clean with brake cleaner until it was looking like new. Put everything back together an started the car, rattle was there for about 3 seconds and went as soon as the oil got pumped up, car drives much better and no rattle or low oil pressure light anymore. Only long thing was the process to get the pump out having to drop exhaust etc. Thanks alot everyone for all the responses and help. 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted November 17, 2018 Share Posted November 17, 2018 I think the gunk is from short journeys , engine not getting hot. Condensation in engine mixing with the detergents of engine oil causing a sludge. Quote Link to comment Share on other sites More sharing options...
cheshire13 Posted December 2, 2019 Share Posted December 2, 2019 Does anyone have a diagram of where the pump is? My 2012 Focus with a 1.0 is doing what is described. Thanks for any and all help. Quote Link to comment Share on other sites More sharing options...
SpeaktoMark Posted March 7, 2020 Share Posted March 7, 2020 On 12/2/2019 at 9:43 PM, cheshire13 said: Does anyone have a diagram of where the pump is? My 2012 Focus with a 1.0 is doing what is described. Thanks for any and all help. Mine is exactly the same I’ll drop the sump tomorrow and give it a clean see how wen go... the rattle you hear by the way i think is the vacuum pump staved of oil.. I’m in my 2nd vacuum pump Quote Link to comment Share on other sites More sharing options...
Jeipii Posted March 8, 2020 Share Posted March 8, 2020 I would be cautious about this since what I believe is that sludge blocking the strainer is parts of the timing belt. At least it has been like that in a few cases. This means that the belt can snap at some point. Quote Link to comment Share on other sites More sharing options...
Worthyo Posted May 7, 2020 Share Posted May 7, 2020 The Ecoboost engine has timing belts running in the oil sump. Deposits from the belts get stuck in the primary oil pump inside the sump causing low oil pressure and camshaft timing faults causing engine light and rattle. Remove sump( exhaust off, etc) and remove deposits) more info on my YouTube channel Worthyo Quote Link to comment Share on other sites More sharing options...
