EGR valve location
Fordfootforward
 Share
I had the dreaded engine management light on along with the p0400 code. (EGR valve malfunction)
going to try giving the valve a clean and just need you wonderful lot to tell me exactly where it is on my engine?
It is a 2.0l petrol duratec he in a 2007 mk2 focus
Excuse the dirtiness ( that’s the next job !!)
thanks in advanceimageproxy.php?img=&key=ab107308399acee6imageproxy.php?img=&key=ab107308399acee6
Link to comment
Hi iantt,
thank you for replying, your engine looks like a different layout to mine, I can’t seem to find anything that looks like the thing your pointing to... the only thing I thought it might be is here where I have marked.. any thoughts??
Cheers 🙂
Link to comment
For the avoidance of doubt I've highlighted the EGR on the pic supplied by Iantt.
I recently cleaned the EGR on the 1.8 Duratec (MK2.5) which is basically the same engine, one of the bolts is an absolute "bar steward" to get to, even with the large rubber coolant hose removed.
Below is a pic of the unit partially removed, I found the right hand bolt to be the one that was difficult to access, it was partially obstructed by the plastic pipe/housing shown in the top picture.
Image result for 1.8 duratec focus egr
Link to comment
24 minutes ago, Fordfootforward said:
Wow that’s spot on thank you 1979damian, I will take the air intake pipe (thanks iantt) off this weekend and have a look.... what did you clean your valve with please?
Now worries mate, I used carb cleaner and just made sure it had all dried out before I refitted it.  In the picture, the top plastic part can be easily separated to make cleaning easier, just remove the 4 screws and start spraying!
Link to comment
  • 2 years later...
On 12/23/2020 at 2:57 AM, MKII.VJ said:
I’m about to remove the egr valve and wondering if it’s recommended and less hassle to buy a new part or is the cleaning effective for long enough?
I ended up replacing mine after it started to misbehave about a year after I cleaned it.  It's also a bit of a sod to remove due to awkward access, so personally I'd recommend just replacing it if you're going to go to the trouble of removing the current part for cleaning etc.
Link to comment
  • 4 months later...
Just bumping my old thread.. I never got round to cleaning it, just bought a code reader and regularly delete the p0400 code. However, I now have a spare bit of time and want to have a crack! So can you guys confirm please this is the valve?
do I need to disconnect the battery before removing the electrical connector?
is it just as simple as those four screws on top?
any help I would really appreciate thank you
Link to comment
  • 11 months later...
Elvis....Where exactly is this egr valve? The parts store says this is the one I need for my 2006 Ford Focus 2.0L. But I can't find it or get to it? Help if you can? Thanks in advance!!
Link to comment
Right hand side of the engine (if you're looking at your car from the front), there's a large coolant hose that sits in front of it.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
